Mud Flaps
Old May 1, 2011 | 05:20 PM
Biggziff's Avatar
Biggziff
Mud Flaps
I know there are a few threads discussing mud flaps, but I've only seen a handful of flaps mentioned in them. I've always used the Ford formed flaps, but wondered what you installed or had installed?
Thanks
Old May 1, 2011 | 05:47 PM
lakedweller's Avatar
lakedweller
Put Huskeys on mine took less than an hour....
Old May 1, 2011 | 05:50 PM
wiedsworld's Avatar
wiedsworld
Husky's here, easy to install and fit great!
Old May 1, 2011 | 07:07 PM
robroy90's Avatar
robroy90
I tried the weathertech today, but I think I got the wrong ones. I ordered them for my SRW and I specified "with fender flares" and there is a gap. I am going to call them tomorrow. I liked them because they are No drill and use existing holes.
Old May 1, 2011 | 07:10 PM
mhoefer's Avatar
mhoefer
Go for the no drill and plastic bolts oif you can get them. My 2005 uses metal self tapping hardware and i am geting rust at the bottom corner holes. If you use the stock ones, with plastic hardware then you dont get this problem. If you are mounting with metal eventually you get the rust climate depending.....
Old May 1, 2011 | 07:18 PM
marchare011's Avatar
marchare011
I went with the 23" Luverne solid rubber with the bling on the bottom, for the front and rear of my DRW.
Old May 1, 2011 | 07:20 PM
Marauder92V's Avatar
Marauder92V
I saw trucks with the plastic formed ones. Just weren't manly enough for my truck. I went with DuraFlaps. Big truck quality. Stainless steel hardware and you can have inserts installed in the flaps as well.
jack_pine's Avatar
jack_pine
I know a lot of folks are custom people here, but....are the ford ones any good?
Old May 1, 2011 | 07:48 PM
dschuffert's Avatar
dschuffert
I have never tried the Ford brand. I put the WeatherTech on. They look good, install easy using factory holes, and only took about 5 minutes a wheel.
Old May 1, 2011 | 08:02 PM
kper05's Avatar
kper05
No drill Duraflaps here.
Old May 1, 2011 | 08:06 PM
jack_pine's Avatar
jack_pine
so, am presuming the after markets are cheaper/better?
Old May 1, 2011 | 08:11 PM
cford716's Avatar
cford716
Husky on mine, quick and easy.
kper05's Avatar
kper05
I don't know since I've never had the Ford built flaps.
I simply liked the Duraflaps and the brand has been discussed here quite a bit.
Item # FF 2 11 and #FR 2X 11.
$170.00 to my door.
I didn't get the chrome weights.
Truck has too much chrome already.
Old May 1, 2011 | 08:13 PM
mach8274's Avatar
mach8274
Deflecta-sheild with diamond plate inserts bought from amazon.com...
Old May 1, 2011 | 08:32 PM
jack_pine's Avatar
jack_pine
Very nice..................
