Best 460 camshaft for gas mileage and towing?
Old 05-01-2011, 03:28 AM
1986F350witha7.3's Avatar
1986F350witha7.3
1986F350witha7.3 is offline
Who has the best 460 camshaft for gas mileage and towing? Brand and model, what are your experiences with the various grinds that are out there.
Engine is a .040 over 1979 460.
Carburetor will either be 600 or 750 cfm AFB.
Gears are 3.54.
Transmission C-6
Chassis is a 1986 F-350 crew cab
Stock compression and heads. I might be willing to mill the heads; if you guys have noticed significant gains.
I will occasionally be doing heavy towing.
Old 05-01-2011, 03:44 AM
460/5's Avatar
460/5
460/5 is offline
Zombie Survivalist
millin a couple thous off the heads will help more than you might realize. those compression points count, and were in rather short supply through the 80s. personally, im a huge fan of crower cams. just follow the tabs on their page. for most of the cams, it tells you were the cams powerband is gonna be at. of course, it will change a little dependin on your setup, but it gives you a ballpark. crower.com
Old 05-01-2011, 09:16 AM
fasthauler's Avatar
fasthauler
fasthauler is offline
Cams are like women they are pretty much the same, but everybody has their own personal likes. I had the Crane RV cam in mine, but couldn’t get it through California smog and had to remove it. It is laying around in a box somewhere. I think I will put it is the classifieds someday. The moral of the story is; if you are in a heavy smog test state be careful. You might not get it through smog testing with a modified cam in it.
Old 05-01-2011, 09:44 AM
miottimouse's Avatar
miottimouse
miottimouse is offline
i like comp cams old school '260 or 268' the 260 is very good for low end tork the 268 [what i am running now in my 79f350 s/c w 12ft camper] pulls a lot better from the line and holds the speed on the highway/hills fairly good with out putting your foot in it all the way even with the gearvenders overdrive/c6/3.73 gear/edelbrock intake/600cfm carb/headers/2.5' duels set up and i get an honest 12mpg with the 2500lb camper on and about 15 empty [canadian gallon=4.5 ltrs] american gallon would be 3.8 ltrs
the only thing i would do differnt would be to run stock lifters not impressed with the comp cams ones i got with the kit they seem to rattle a bit much[noisy]
Old 05-01-2011, 10:22 AM
460/5's Avatar
460/5
460/5 is offline
Zombie Survivalist
gary, keep that crane cam. crane went under, so it could be a novelty item in the near future.
Old 05-01-2011, 11:21 AM
hasteranger's Avatar
hasteranger
hasteranger is offline
I doubt it.. .they made a **** ton of cams before they went under. But pretty much any "RV" grind has the goal of low end torque and fuel economy. How it actually performs for you will depend a lot on your gearing and stall converter if an automatic.
Old 05-01-2011, 04:57 PM
KrautBurner's Avatar
KrautBurner
KrautBurner is offline
Let me know when u r ready to get rid of it.
It may ne a food option for my 77 supercab. With a slide in camper
Old 05-01-2011, 06:23 PM
fasthauler's Avatar
fasthauler
Maybe I'll frame it and hang it on the wall.
Old 05-02-2011, 02:39 AM
460/5's Avatar
460/5
460/5 is offline
Zombie Survivalist
hells yeah! or maybe make a lamp out of it... lol.
Old 05-02-2011, 02:40 PM
KrautBurner
I was goimg to keep my origional cam from my GTO.
Then someone with a truck asked for it. Now, he has a 400 hp avelanche
1986F150six
Oil & Lubrication
04-13-2015 10:02 AM
Dr OConnor
01-28-2012 02:38 AM
Dr OConnor
13
01-27-2012 08:37 PM
datsun147
04-25-2011 12:41 PM
AceCalibre
22
02-12-2011 01:57 PM
Quick Reply: Best 460 camshaft for gas mileage and towing?
