remove thermactor air??
Old Apr 29, 2011 | 10:29 PM
Super Econoline's Avatar
Super Econoline
I have 87 E250 351 4 barrel carb
there already remove air pump when i bought it
so, i just wondering if i can remove themactor air in back of both head and block plug on it? is it safe??
if does safe then where can i find block plugs on both head?
Old Apr 30, 2011 | 11:11 PM
jimbbski's Avatar
jimbbski
Yes you can remove the "crossover tube". To plug the holes left you will need 2-5/8-11 bolts. Most likely the threads will be carboned up. The best way to clean the threads is to get the correct tap and chase those threads, then using sealer insert the two bolts.
Old Apr 30, 2011 | 11:15 PM
Super Econoline
ok where i should buy bolts? just grade 5 bolt from ace hardware? thanks,
paintubturner
Jul 10, 2017 10:58 PM
bjmayberry2
27
Aug 30, 2016 05:48 PM
73FOMO
2004 - 2008 F150
Aug 31, 2015 10:25 PM
19903934x4
34
Oct 1, 2009 01:00 AM
wrencher1547
Sep 2, 2009 07:48 AM
