Got a 96 all stock. Once in awhile when I start my truck and take off ill get to about 2200 rpms in 2nd gear and seems I loose all power I can floor the pedal and get nothing switch to third and nothing but when I take it out of gear and rev it for awhile put it back in take off and its fine. Turbo maybe?
Another question I've noticed when in gear I can have the pedal at quarter throttle then full throttle with no difference in acceleration. That normal? Thanks guys
Dvom. What's that? The switch on the go pedal quit working about 4 months ago and couldn't find one so I rigged up a toggle switch. Been working fine I thot maybe not.
I'd say it's a problem with the switch you rigged up. Replace the "custom work" with original equipment and see if you still have the same problem. Even if you do have the same problem, at least you now know that it's not rigged up anymore.
