FLASHING OD LIGHT- resolved
Old Apr 27, 2011 | 04:52 PM
clean '97's Avatar
clean '97
Took truck in and had new windshield put in.drove across town and found door locks would not work,keyless entry would not work.got in and drove 1/4mile starts to hard shift and od light starts flashing. Luckily right next to tranny shop,pulls codes po344-intermittent cps,po500-vss sensor,tries to check abs-no power,for grins he does buzz test-fine,cct pulls p0196-oil temp circuit? i have no interior lights,no speedo,no odometer display.
checked all fuses in relay box in engine compartment,and in fuse panel under dash.all tested fine.when i push the door lock and unlock on the drivers door panel i hear a little click in the grey box under the dash in about the location relative to the transfer case lever.
Anybody have any ideas,I hate to just start replacing sensors if not needed.it sounds more like a power problem to me. Could this have been caused during the windshield installation? i know the power window and power door harness runs along up there.Where should i begin searching now?????? ps: i did not check the relays in the fuse block under the hood
Old Apr 27, 2011 | 05:32 PM
Talyn's Avatar
Talyn
I got something in my drivers side door that shorts occasionally under the switches that makes the door locks and windows not work.
I think the screw has gotten into the wires.
Might wanna pull that screw on the controls there and pull it up and look?
Old Apr 27, 2011 | 06:07 PM
clean '97's Avatar
clean '97
the door panel was off and the control hanging since last night (before this problem started) i'm in the process of replacing the door handle mechanism
Old Apr 27, 2011 | 06:13 PM
Talyn's Avatar
Talyn
Interesting. I'd tell you my findings, but I've been to lazy to tear it open and fix it cause it rarely happens, but I know its something in that control in the door.
Old Apr 27, 2011 | 06:27 PM
clean '97's Avatar
clean '97
Do you think that would be affecting my speedo,odometer,interior lights,rabs unit,vss,cps,etc...?
Old Apr 27, 2011 | 06:36 PM
Talyn's Avatar
Talyn
Well, the wrong short could do all sorts of strange *** things.
I had the cigarette lighter shorting out behind the ash tray on my f-150 and it caused all sorts of problems till I finally found it.
Erratic idling, poor performance, bucking. All weird things.
Though. I'm almost certain yours could be far deeper than that. But I cannot think of anything they could screw up just changing the window out.
Action Rick would have the best places to check, but I have some similar issues from the window/lock controls.
My only other thought is it could be ignition wiring.
Old Apr 27, 2011 | 08:53 PM
clean '97's Avatar
clean '97
I'm a bonehead,bonehead,bonehead.Did i mention i'm a bonehead?
Troubleshooting when you are stressed is probably not a good thing.when testing my fuses i used a continuity tester, not thinking about
about having a light bulb in the circuit(my interior door marker light would be on when the door was open during testing giving me a false reading)
after coming to that realization,pulled the fuse,it was blown,replaced,everything works fine now.Good thing i'm an electrician by trade LMAO. Anyway, william thanks for trying to help.
PS: it was that dangling marker light that shorted out against the door and blew my fuse while i had the door panel off.who would of thought 1 blown fuse would cause so much trouble?
Old Apr 27, 2011 | 09:25 PM
Talyn's Avatar
Talyn
I've had that happen before with the light John. that one really irked me.
Old Apr 27, 2011 | 10:43 PM
clean '97's Avatar
clean '97
yeah sometimes the simplist things can be the most frustrating.now i have to put half of my dash back together that i ripped apart for no apparent reason(lol)oh well, live and learn and hopefully retain.
Old Apr 27, 2011 | 11:28 PM
Talyn's Avatar
Talyn
Yeah, thats what pissed me off about the cigarette lighter thing.
Keepitrunnin
Jan 23, 2020 08:41 PM
wanicholas
Electrical Systems/Wiring
Feb 18, 2014 02:15 PM
Greek 350
Apr 16, 2012 07:43 AM
babstinger
Sep 6, 2010 06:44 PM
falconer
Aerostar
Dec 3, 2005 06:08 AM
