'99 F-150 Battery Draining
Hi all,
My neighbor's kids truck battery drains from full charge to "no start" in 1-2 days.
'99 Ford F-150 w/ 4.6L engine.
He has already.....
1) Replaced the Battery.
2) Replaced the GEM module.
3) Replaced the Turn Signal Relay.
He did all this before I looked at it....
I checked the following....
1) Truck off, doors closed, hood open... Amp meter shows 3.6 amp draw.
When 1st hooked up, shows 4.2 amps... after a while drops to 3.6.
2) To isolate the draw, we pulled fuses while checking current draw at
battery.
a) Under Dash fuse Panel. (Yes, with door closed) We remove fuse #15
"stop lamp switch, speed control, brake shift interlock, ABS, PCM,GEM,
RABS test connector". (Really... couldn't be more stuff?)
b)Under the hood is another fuse box (drivers side). We remove Fuse #103.
"Junction Block Battery Feed".
3) Not sure if this helps... found that if we remove the #15 fuse under the
dash with the door opens, all interior lights flash on/off at about 1 second
intervals... weird.
4) Again, another weird one... with the fuse #15 removed and door closed,
the "ABS" indicator and some other indicators and dash lights are staying
partially lit... not fully lit.
5) The only "aftermarket" stuff i can see is a dealer installed trailer brake system. Wiring looks professional and disconnecting it does not remove the amperage drain.
I'm hoping that one of you wizards will give me the "slam dunk"... if this happens, it must be that. Can I be so lucky?
And, yes. I have my own '06 F-150 that i absolutely love. 6-cyl., manual trans, stripped down without even power door locks... my kinda technology. lol.
Thanks in Advance,
Bill Nicholas
He has already.....
battery.
intervals... weird.
Thanks in Advance,
Bill Nicholas
nsshull
08-14-2005 11:14 PM
