brake booster????
Old Apr 26, 2011 | 11:45 PM
Scolesy8's Avatar
Scolesy8
brake booster????
i know this is just kind of random, but it just hit me and i was curious..... can the old booster be removed and still have decent functioning brakes?or would the pressure created by pedal alone not be enough to create a good amount of pressure? i've heard some large cams can mess with vacuum for the booster and hurt braking efficiency? is there much truth to this?
Old Apr 27, 2011 | 09:00 AM
73FOMO's Avatar
73FOMO
If the booster is removed. You have non power brakes. The booster is what makes it power brakes. It will stop, but it takes a ton of pedal pressure. Also...there is a bit of difference in the brake pedal bend on a power brake and a manual or on power brake and I think the manual design gives a bit more leverage. I wouldn't advise doing it. And yes a real large cam doesn't make as much vacuum. The "power" booster gets it's power from the vacuum created in the motor. The booster is bascially a vacuum diagram that assist you in pushing brake fluid to the caliper pistons. There are ways to help increase vacuum when running big cams, such as vacuum resovoirs, etc. Why would you want to remove the booster?
Old Apr 27, 2011 | 11:08 AM
justforkicks's Avatar
justforkicks
i wouldn't remove it. drive with a shot brake booster and it's the same thing. you REALLY have to lay into the pedal to get one of these old trucks to stop with no booster.
Old Apr 27, 2011 | 12:22 PM
cigarxtc's Avatar
cigarxtc
lol. my booster quit on me a year and a half ago. I drove around with it for a few months. It was not fun at all. I swear the muscles in my right leg grew bigger than my left leg. It took a lot more human power on that pedal to stop my small 1/2ton '78 F150. In the winter time it took both feet on the brake pedal to keep from lurching in stop in go traffic on the snowy roads. Not fun at all.
Old Apr 27, 2011 | 02:30 PM
BuckTruck's Avatar
BuckTruck
My '74 didn't come with one on it, and I have yet to put one on. Now I don't drive it hard, and don't pull anything large or race it or anything like that, but It does fine for just cruising around. Can I tell a difference, definately. In fact, If I have time this summer I may take one off of one of my parts trucks and put it on. but, you can get by without them. Wasn't '73 the first year for a brake booster? They had plenty of big trucks and engines before '73.
Old Apr 27, 2011 | 02:41 PM
73FOMO's Avatar
73FOMO
If you have the option to run I would highly encourage doing so. It's just plain scary not being able to stop. My '73 was manual with front disc and rear drums, but have since converted to power. I think there were power boosters before '73 though.
Old Apr 27, 2011 | 03:31 PM
Scolesy8's Avatar
Scolesy8
im not wanting to eliminate mine, i have went through my ENTIRE brake system and it works just the way i want it to... and plus i need the brakes. but it was just something that came to mind when i was over at a buddies.... trying to free up some firewall space in his pulling truck.
Old Apr 27, 2011 | 03:36 PM
73FOMO's Avatar
73FOMO
If is pulling and has to stop what it is pulling. DEFINTELY NO.
Old Apr 27, 2011 | 03:40 PM
hapkidocrochunter's Avatar
hapkidocrochunter
Those brake stories reminds me of the 76 trailerspecial i used to have. The booster was shot, and you had to REALLY anticipate your stops, and push a lot harder then i wanted to on a brake pedal to get it to stop. Not a fun thing to do.
Matt
Old Apr 27, 2011 | 03:48 PM
73FOMO's Avatar
73FOMO
Matt
Yeah...makes you want a fighter pilot ejector seat, just in case.
masscoalroller
Aug 24, 2016 07:19 PM
NHSPRET
Jul 24, 2016 08:52 AM
Chef Tim
Jul 23, 2015 01:09 PM
rsdjcarter
Oct 4, 2008 02:49 PM
Bobby82490
Escape & Escape Hybrid
Sep 9, 2008 12:50 PM
