Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Leaking Brake Booster
Old Aug 16, 2008 | 03:24 PM
Bobby82490's Avatar
Bobby82490
Well my moms Escape started to leak where the brake pedal rod goes into the booster. So can i just replace the seal? Or do i gotta replace the whole booster?
Old Aug 16, 2008 | 07:58 PM
bmuhlbach's Avatar
bmuhlbach
should have to install mastercylinder only. Do not put it off if your mastercylinder is leaking the brake pedel will go to floor. A little at first then you loose your brakes all together.
Old Aug 16, 2008 | 10:58 PM
Bobby82490's Avatar
Bobby82490
No not the master cylinder.. the brake booster. If the leak got bad enough on the booster.. then all that would happen is that i wouldnt have power brakes anymore.
Old Aug 18, 2008 | 03:07 PM
Bobby82490's Avatar
Bobby82490
bumpity..bump
Old Aug 21, 2008 | 01:14 PM
Bobby82490's Avatar
Bobby82490
Soo... is it possible to replace just the seal or do i gotta pull everything apart to replace the booster?
Old Sep 9, 2008 | 12:50 PM
MMSCHWE's Avatar
MMSCHWE
How much work is it to replace the master cylinder?
A couple bolts, a couple brake lines, then bleed the brakes?
Or is there more to it than that?
forango
Mar 13, 2017 03:31 PM
Mikulh
Dec 27, 2016 09:04 AM
Rusty_S
Oct 1, 2016 11:34 AM
Redagain
Aug 29, 2015 10:58 PM
