FICM TEST PROCEDURE ???
Old Apr 26, 2011 | 07:54 PM
1bad04's Avatar
1bad04
Sorry guy's I know i'm really picking your brain week LOL. As you all know I been chasing a low power problem for a while. So along with cleaning the turbo over the weekend I decided today to change the fuel filters, and give her a fresh oil change. Yes Motor craft filters and Rotella oil just to rule then out! Still no better. Ok then I figured while im at it I would check the FICM. My question is when following the first step as it says to turn the key to on position does that mean just 1 click of the key before the injector 2nd click buzz? Because I wasn't getting any volt reading at this point. Only got 48v when I buzzed the injectors and 47v while cranking. So im I doing something wrong or is me FICM Bad and the root of my low power problem? I have mentioned before that my engine sounds alot quieter along with this problem. But today it got really bad and sounded really faint. almost as if it wanted to shut off but continued to run all day.
Old Apr 26, 2011 | 08:15 PM
BLADE35's Avatar
BLADE35
did it stay at 48volts when it was running
Old Apr 26, 2011 | 08:38 PM
Dieselpop's Avatar
Dieselpop
Have you look at this YouTube - Ford 6.0 FICM Testing & Removal Instructional Video
pop
bigbeariron
Sep 24, 2020 07:49 PM
ntence2
Jun 29, 2017 11:26 AM
johnl2
Apr 9, 2017 01:36 AM
hooptytank
Jul 27, 2015 10:26 AM
brandon.edwards
Mar 24, 2014 01:47 PM
