05 EX buffing smoke and missing when hot
Old Jun 7, 2017 | 01:23 PM
ntence2's Avatar
ntence2
Hello Everyone, this is my first post. I have been doing every bit of work on my truck so far with just a search once in a while but now Im stuck and need your help. I purchased the truck last summer with 127000 on it and completely stock except the egr delete
heres the list of whats done.
egr delete with edge tuner 80hp tune and egr off
bullet proof oil cooler plate with custom cooler and filters, i rung the factory filter and the amsoil bypass kit,12an lines and 185 thermostat.
new hpop in the fall
4 new injectors, 4 buzz tested good injectors with good seals. new nipple cup o-rings and new plug and stand pipes.
pressure tested at 120 psi and the only noise was some of the injectors would pop oil out of the exhaust on the injectors, the 2 holes on top, it was a snapping sound. some of the new and old ones did it. new injectors, not reman form KT.
new IPR and ICP, idle doesn't change when the IPC is unplugged.
new 240a alternator, fully charged batteries and a third bat on a isolation relay, only connected when running.
AE shows 47 volts when cranking and 47.5 when running on the FICM
ipr is about 30% at idle.
desired and actual pressure are dead on.
turbo vanes cleaned last winter, and looked good.
4" turbo back
new fuel filters and blue spring, holds 65 ish psi at idle.
fresh oil and filter, t6 oil.
there was a lot of fuel in the last oil change after I did the injectors, i figure having 4 out for a week may have leaked into the cylinders. never had that before on any other change.
heres the problem.
starts great, short crank and it fires. sometimes it feels like its missing when driving. then when it get to temp it starts surging or missing at idle, it will even kill the truck, when it does this it puffs black smoke.
AE shows all cylinders equal but when it surges they all spike then drop. when I buzz test all buss fine then number 4 doesn't always single click, I've swapped 4 with other injectors that I know work and its always the same 4 doesn't want to click. number 4 is right under the FICM and the harness isn't chafed at all, so I dont think its the harness, I also moved the harness while running and nothing changed. I also have reset the connectors multiple times on the FICM. theres no codes either, there was before I changed the ICP, but not anymore.
I really hope someone knows what is going on, its driving me nuts. Thanks for the help guys!
the youtube of how its running and the pid's plus the contribution.
Old Jun 7, 2017 | 09:40 PM
SmokyBear's Avatar
SmokyBear
I don't have an answer to your question, but I recently bought a 2003 F250 151,000 miles all stock, and it has the same issue. Truck runs great cold but misfires when warm. Mine shows cylinder 1 as missing but no codes. Getting ready to replace injector 1. I'll keep you posted.
Old Jun 8, 2017 | 07:36 AM
ntence2's Avatar
ntence2
I may be closer to figuring this out. i checked base oil pres last night. its 70 when it starts and starts dropping from there. it starts this missing thing around 40 psi but revving and bringing the psi up doesn't make the issue go away. I'm thinking about trying a thicker oil to see if that helps.
Old Jun 8, 2017 | 10:54 AM
2006powerstroke90's Avatar
2006powerstroke90
IPR @ idle seems a bit high @ 30% I think your headed in the right direction with the oil issue....IPR should be 22/23% @ idle
Old Jun 8, 2017 | 11:37 AM
ntence2's Avatar
ntence2
I thought so too but everything in the lpop and hpop system check out or is new.
the only thing I could see making it 30% would be a leak but Ive checked it and there are none.
Old Jun 9, 2017 | 07:25 AM
ntence2's Avatar
ntence2
heres something strange. i tried with the ac off last night and the problem almost goes away. I checked the grounds and even tried a different alt. i'm at 14.1v at idle. Im thinking either its load or its electrical in some way. but its still idling at 30% ipr.
I also pulled the tune and turned the egr back on to see if that would do anything.
Old Jun 9, 2017 | 11:17 AM
DarkStarMedia's Avatar
DarkStarMedia
Where are you? maybe someone local has IDS and can do an un-compensated balance. I don't think AE can do that.
Ricahrd
Old Jun 9, 2017 | 11:22 AM
ntence2's Avatar
ntence2
I'm in the south Dayton Oh area.
i was watching it last night because it was doing it bad, everything the contribution would drop low then spit the smoke and ti smelled like kerosene. so its dumping a bunch of fuel or its not burning it.
Old Jun 29, 2017 | 07:03 AM
ntence2's Avatar
ntence2
update!
took the truck to a local diesel shop and they couldn't figure it out.
last night i drove it for a while, it starts to feel like its running on 6, and puffs smoke.
when i got home and it was hot abut 185, I tried restarting a few times. each time the factory buzz test quit.
Im thinking the ficm logic board is toast when hot.
any thoughts?
Old Jun 29, 2017 | 10:02 AM
navistarnut's Avatar
navistarnut
Give Ed at ficmrepair.com a call. I had a bad logic board and didn't really even know it at the time. It almost sounds to me like you have a solder opening up after it warms up and killing a connection somewhere. It would perhaps explain the unburnt fuel if you have an injector or two not firing properly.
Old Jun 29, 2017 | 11:26 AM
ntence2's Avatar
ntence2
thats what I was thinking too!
Im sending it to ficmfixer in texas for testing. he's half the price as ficmrepair. I wish I had someone local that could test it but Im new to the state and dont know anyone here.
04 6.0 Powerstroke
Mar 21, 2019 07:14 AM
abowman
Mar 19, 2018 10:23 AM
GR8Dane
May 5, 2017 09:47 PM
embry1123
Jun 21, 2011 01:49 PM
aocabrown
Jan 2, 2008 01:28 PM
