1959 ford panel speedometer gear
Old Apr 26, 2011 | 07:02 PM
panelford59's Avatar
panelford59
Thumbs up 1959 ford panel speedometer gear
Looking to find what number of teeth for the speedometer drive gear to use.3 speed manual ,292 motor.Transmission tag HEFAU 044538
Old Apr 27, 2011 | 01:56 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by panelford59
Looking to find what number of teeth for the speedometer drive gear to use. 3 speed manual, 292 motor. Transmission tag HEF-AU 044538
Welcome to FTE
Which speedometer drive gear (on the output shaft) and/or speedometer driven gear (end of the speedo cable) is correct...depends on several factors.
Trans type, rear axle ratio, tire size. The engine size usually has nothing to do with it.
HEF-AU: Ford type 3.03 3 speed manual all sycromesh transmission.
Applications: 1963/64 F100/250 292 installed in these trucks with 114" & 120" wheelbases.
The type 3.03 was introduced in 1963 Passenger Cars, F100/250's. Would not have been factory installed in anything earlier. This trans has many other applications after 1964 and was used thru 1987.
Mikemakeswine
19
Nov 19, 2017 01:17 PM
Stevenbowman23
Mar 23, 2015 12:12 AM
JacobRM
19
Jun 3, 2014 06:35 PM
Yogis1097
Jul 19, 2006 06:38 PM
