5th wheel hitch question
Old Apr 26, 2011 | 12:47 PM
tonym1069's Avatar
tonym1069
Hello,
I just purchased a 2006 F350. I was looking at 5th wheel hitchs. I have no idea what to look for, how to tell which one would be easyer to use. What a high quality hitch looks like. The price of the hitchs surprized me, as I am looking at a good chuck of change I am looking for advice. All the shops in my area are pushing Reese hitchs. I looked on google there seem to be about 5 companys listed (reese, curt manufacturing, Valley, Pull rite, and Cequent). I am looking at Curt Manufacturing, because on Amazon they seem to have good reviews. I am looking to purchase a 35ft trailer, so want a 20k lb hitch. Thanks for the help.
Tony
Old Apr 26, 2011 | 01:02 PM
bpounds's Avatar
bpounds
Curt gets high marks from owners. But they are all good really. Hitch brand loyalty starts looking a lot like religion after a while. I don't think you can go wrong with a Curt from Amazon, even though I own something else.
The big question is, slider, or not? Auto slider, or manual?
Be sure you go for a 4 way rocker.
Old Apr 26, 2011 | 01:20 PM
senix's Avatar
senix
Another question you have to answer is do you want/desire to have a hidden hitch or do you want the rails in the bed of the truck.
That was what pushed me to the Reese I have.
Signature series 18K slider.
Old Apr 26, 2011 | 02:31 PM
Old Rusty Wrench's Avatar
Old Rusty Wrench
I have a 1998 15K Reese that I found has a single point failure. The jaw locking system has a C-clip that holds the system together. I had just parked at home, (backing up), released the locking lever, pulled the jaw unlock handle and found the jaws were already unlocked. Good that the last move was backing. I took the hitch off to find the problem. A C-clip had fallen off. Went to the best nut and bolt store to find a clip to fit the pin that holds the parts in place. They could not fit one to the pin. Tried to call Reese on the problem but only got a sales outfit. Had to buy some new parts, nut, bolts and lock pins to make the hitch safe. Before you buy one check the underside of the hitch for C-clips that may fall off and allow the jaws to unlock.
Old Apr 26, 2011 | 03:46 PM
89LX306's Avatar
89LX306
I have a Pullrite Superglide. Love it! It is an auto slider as I have a short bed. Works great. It also has the rails under the bed, so it only leaves 4 holes in the bed when I remove it, giving me full use of the bed.
Old Apr 26, 2011 | 06:53 PM
Gearitis's Avatar
Gearitis
I have a Husky and really like it. Breaks down into 2 parts and easy to remove. Yes, I still have the rails in the bed, but no big deal...
Old Apr 26, 2011 | 08:02 PM
SUPERDUTY_08's Avatar
SUPERDUTY_08
I have a HUSKY slider with mounting rails under bed. Comes out easy, never had any problems. This is what the RV deal was selling. [IMG]
Old Apr 26, 2011 | 10:50 PM
TexasRebel's Avatar
TexasRebel
If you don't need a slider...
B&W Companion.
Old Apr 26, 2011 | 11:10 PM
lakedweller's Avatar
lakedweller
I have a 35" and its max weight is 14,500 lbs. I have a Reese16K square tube slider. I would select a 5er first then determine the hitch you will need. I do not think there are any 20K 35' 5ers out there, I may be wrong.
Old Apr 28, 2011 | 09:05 AM
tonym1069's Avatar
tonym1069
Thank You
Thanks for all the info. I was looking on ebay and there are a lot of hitchs out there for a lot less. So I think I will speed some time looking at differnt ones. I think I will find a good one and learn alot. Yes I just purchased a 32 ft trailer, and the weight is 7,400 lbs. So the 20k would be a little much. But you now how it is when you first get into something you want the best and the biggest.
Old Apr 28, 2011 | 09:27 AM
bpounds's Avatar
bpounds
Check Craigslist too. I see them on there every day. Usually without rail kits, but those are pretty cheap.
Old Apr 28, 2011 | 03:30 PM
89LX306's Avatar
89LX306
This is a good place to look to look at a variety and know what to expect price wise. I second Craigslist. I got my Superglide for $600 on there.
Fifth Wheel Hitches from Reese, Pullrite and More form tweetys.com
Greengas
Oct 28, 2017 03:48 AM
shortedout96
Dec 11, 2016 01:43 PM
Tomahawk
6.7L Power Stroke Diesel
86
Apr 3, 2016 06:02 AM
gsxr1300
86
Apr 28, 2014 06:17 PM
Bozo123
All Things Towing
Oct 9, 2011 06:29 PM
