Fast blinker Right
Old Apr 24, 2011 | 06:06 PM
dentaldave's Avatar
dentaldave
Fast blinker Right
I can't seem to figure out a problem that just started with my right blinker on my 2006 F250 6.0. When I turn the blinker on all the way it does a rapid flash and the bulb in the front does not light up but the one in the rear lights and rapid flashes.
I replaced the right front bulb and it did not fix the problem. (the old bulb looked good)
I swithched the relays (right with left) in the fuze box under the hood and nothing changed.
I checked all the turn signal fuzes and all seemed to be fine.
Can anyone advise me as to what to try. Thanks in advance.
dentaldave
Old Apr 24, 2011 | 06:27 PM
bismic's Avatar
bismic
Sounds like the issue is w/ the wiring or connector to the right front bulb.
Old Apr 24, 2011 | 07:10 PM
rdunagan's Avatar
rdunagan
change the blinker fluid! JK yea what bismic said
Old Apr 24, 2011 | 09:56 PM
dentaldave's Avatar
dentaldave
The right front bulb flashes when I turn on the EM Flashers so I know the connector to the bulb is good. This does not sound good if there is a problem hidden somewhere in the wiring. Thanks for the help anyway.
Old Apr 25, 2011 | 03:17 PM
Misky6.0's Avatar
Misky6.0
DentalDave:
Try your right turn signal WITH and WITHOUT your parking lights on.
There is a "front side marker" light that also blinks,
but opposite to the "front turn signal".
It could be the problem with the turn signal is the side marker bulb.
With the 4-way (emergency) it's not effected by a missing bulb.
Also check your side marker with the 4-ways going.
Old Apr 26, 2011 | 10:29 AM
dentaldave's Avatar
dentaldave
Thanks Misky6.0, I will check this when I get home.
Also thanks for not suggesting the "blinker fluid" solution!
Old Apr 26, 2011 | 10:47 AM
Misky6.0's Avatar
Misky6.0
Was that intended to be a pun?
Let us know, electrical things are always weird.
But, "most" of the time they are obvious - once you figure it out.
Old May 10, 2011 | 11:41 AM
dentaldave's Avatar
dentaldave
I finally checked that side bulb... it is good.
The right mirror has a blinker within it as well and that is currently broken... Would that cause the rapid blink? I can't exactly remember but I think the mirror was broke before this became a problem.
I am afraid this might be one of those mysterirous electrical problems never to be solved.
Old May 10, 2011 | 11:53 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Me thinks that if ANY bulb in the blinker system is non-functional, it will affect the blink rate as it changed the load on the electronics.
miihere24
44
Jan 14, 2016 12:32 PM
rossseger
Nov 3, 2014 02:09 PM
drewduncan15
Dec 31, 2012 05:38 PM
charlesTX
Mar 21, 2009 08:57 PM
jmcary02
1997 - 2003 F150
May 19, 2004 10:22 AM
