1966 - 1977 Early Broncos
Need starting help
Old Apr 24, 2011 | 12:17 AM
MonsterTruck\m/'s Avatar
MonsterTruck\m/
Need starting help
I have a 68 bronco with a 77 302 engine,
So i replaced the starter yesterday, truck started repeatly with no trouble, i went mudding and then it decided to not turn on again. I clean every connection perfectly and every ground however when i turn the key the solenoid clicks but no starter. I also checked with another battery
I can not jump start the bronco but i can rolling bump start it. please help me
Old Apr 24, 2011 | 07:56 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Take one lead of your jumper cable and put one end on pos batt and touch the other on the starter side of starter relay. If starter doesn't attempt to turn, starter or cable to starter is bad. If it does, the starter relay went bad. New starters go bad too.
MBBFord
Electrical Systems/Wiring
Oct 3, 2006 11:07 PM
igota92bronco
1978 - 1996 Big Bronco
Dec 9, 2005 12:26 PM
Highguy
Dec 27, 2004 08:56 AM
Barry M
May 1, 2003 07:36 PM
maulsmasher
Mar 27, 2003 10:09 AM
