1978 - 1996 Big Bronco
delayed start
Old Dec 9, 2005 | 10:58 AM
igota92bronco's Avatar
igota92bronco
delayed start
Man if it aint one thing its another. So I finally got my bronco to start. Now every now and then I get this delayed start. I go to start it and nothing, the starter doesnt crank over or anything. I went down to see if the wire was loose cause I've had that happen a few times before but it was fine. So when I turn the key nothing, but if I leave it turned for a few seconds it will all of the sudden fire up. bad wires? something else?
thank again for any help
Old Dec 9, 2005 | 12:13 PM
greystreak92's Avatar
greystreak92
That sounds like loose connections or corrosion resistance. Ive seen this happen with those silly slip-on booted connectors at the solenoid on the inner fender. The trigger wire from the ignition switch (little pink one I think) came from the factory with this setup. They can get loose or oxidation inside them. The truck starts after a few seconds holding the key because the resistancs builds up heat and the stud on the solenoid expands and makes the connection tighter. I know it sounds silly but electricity is more fickle than a 16 y/o female an hour before her first high school dance.
Old Dec 9, 2005 | 12:26 PM
igota92bronco
Ive seen this happen with those silly slip-on booted connectors at the solenoid....... Hey thats what I got..if we werent getting a friggen noreaster up here right now I would probobly go check it out.
thanks for the info
caslerst
Apr 17, 2017 11:37 AM
e6ug
Feb 22, 2016 01:32 PM
DDiamelle
Sep 2, 2015 05:20 PM
StanleyZ
Jun 26, 2013 04:31 PM
Praesul Presul
1997 - 2003 F150
May 1, 2012 03:22 PM
