96 e350 dies in reverse
Old Apr 21, 2011 | 05:27 PM
7.3 Rocket's Avatar
7.3 Rocket
1996 e350 auto dies when put in reverse. Any thoughts?
Old Apr 21, 2011 | 08:40 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Low trans fluid, loose/missing internal filter, worn seals, worn pump, bad torque converter.
Old Apr 22, 2011 | 12:01 AM
7.3 Rocket's Avatar
7.3 Rocket
Thanks, Mark. Looks like I'll check fluids and go from there.
Old Apr 27, 2011 | 08:37 PM
kmulholl's Avatar
kmulholl
you mean "dies" as in engine shuts off? i don't think low fluid would cause that. i'd say more likely ignition wires shorting out in steering column when you shift.
or reverse lights wiring crossed with ignition somehow.
Old Apr 28, 2011 | 07:11 PM
Mark Kovalsky
Low trans fluid can make the the engine die, or shut off. It allows the torque converter clutch drift on. That's just like applying the clutch in a manual transmission.
If you'd like to debate how an automatic trans works I'm up for that!
beckman
2004 - 2008 F150
Jan 18, 2021 08:23 PM
hotshothauler
16
Nov 13, 2016 05:16 PM
E-350CargotoCamper
Jul 20, 2013 06:17 PM
94 Green Beast
33
Jun 20, 2011 06:28 PM
