Dash Swap Help
Old Apr 22, 2011 | 07:54 PM
ctubutis's Avatar
ctubutis
This avatar was actually made by a member here and given to me to use.
I don't understand the ear comment, though....
Old Apr 22, 2011 | 08:26 PM
WoodHeat's Avatar
WoodHeat
Originally Posted by Eddiec1564
As you have the dash out, its a good time to fix any rust on the firewall area.
So basically just sand it down and paint over it?
Old Apr 22, 2011 | 08:27 PM
WoodHeat's Avatar
WoodHeat
Because your old one seemed like it was on your ears...lol
Old Apr 23, 2011 | 09:21 PM
Eddiec1564's Avatar
Eddiec1564
You can sand it down and repaint it. I did that to my 89 F250, had dash totaly out and fixed a seam leak and used some bed liner paint. So far it's holding up. Can't hurt to prevent any future problems.
Me bad, Ctubtis, I was thinking about Bugs Bunny running around with the bra on his ears on one of the "sensored" shows.
Old Apr 25, 2011 | 04:35 PM
WoodHeat's Avatar
WoodHeat
Man, ya'll were totally right about the dash being easy to take out with the correct tools and process. I picked up a universal socket joint and was able to get at the bolts near the windshield easily. Dropping the steering column a bit helped a bunch too.
Old Apr 25, 2011 | 09:59 PM
ctubutis's Avatar
ctubutis
Originally Posted by WoodHeat
...Considering that there is only about 1" of space between that and the metal behind it, I couldn't even get my stubby screw driver to grab it. Friends...that's my definition of evil right there...to get to it properly I would have had to take all of this apart:
As an aside/FYI, here is the module that turns the Emissions light on.
Old Apr 26, 2011 | 02:32 PM
WoodHeat's Avatar
WoodHeat
Sweet, I was going to ask what that was for! Thanks!
Old Apr 26, 2011 | 03:13 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Trash can filler, in my opinion. Too difficult to access when it's time to turn that light back off......
The light just comes on after a certain amount of time. Has nothing to do with whether there is any issues with the system or not.
Old Apr 26, 2011 | 04:45 PM
WoodHeat's Avatar
WoodHeat
Will disconnecting it cause a fault code?
Old Apr 26, 2011 | 06:39 PM
Rogue_Wulff
I'm not sure on the EFI version, but I kinda doubt that it is even tied into the computer. This same item was found on some non-computer controlled trucks.
Old Apr 26, 2011 | 07:32 PM
ctubutis's Avatar
ctubutis
To my knowledge, 1988 was the first year of a dash light controlled by the computer,
hopefully others will answer more definitively.
Along those lines, I believe you can disconnect it and it won't cause a problem.
More here:
https://www.ford-trucks.com/forums/1...missions+light
dukedrummer89
39
Jan 6, 2016 08:58 PM
SCRebel
62
Feb 18, 2013 11:47 PM
jwhopson
Jan 2, 2013 04:41 PM
65Ranger
Feb 27, 2012 07:59 AM
PaysonPSD
13
Jul 1, 2010 01:05 AM
