BOOST QUESTION
Old Apr 20, 2011 | 08:19 PM
White350's Avatar
White350
BOOST QUESTION
i JUST WAS WONDERING WHAT THE MAX BOOST SOME OTHER PEOPLE ARE GETTING IT JUST SEEMS LIKE I SHOULD GET MORE THAN WHAT IM GETTING I HAVE A 2002 F-350 ITS GOT A K&N INTAKE 4INCH STRAIGHT PIPE 6 STEP PROGRAMMER FROM TS (WAS ON THE TRUCK WHEN I GOT IT) DONT NO IF IM REAL HAPPY WITH IT , A OVERBOOST ANNIHILATOR I JUST THINK I SHOULD BE GETTING MORE THAN 23-25 POUNDS OR IS THIS ABOUT RITE. IS THERE ANY LITTLE TRICKS TO GET MORE POWER I HOPE THERE IS I JUST BOUGHT A HOUSE AND DONT HAVE MUCH MONEY TO SPEND AT THE MOMENT
ONE OTHER THING I HAVE A EDGE PROGRAMMER MODEL NUMBER 15000 THE ONE THAT HAS THREE SETTINGS THAT PLUSG INTO YOUR OBD PORT THEN YOU UNPLUG IT WHEN ITS DONE PROGRAMMING I NO ITS NOT GOOD TO STACK PROGRAMMERS BUT CAN I USE BOTH LIKE I SAID I DONT HAVE MUCH MONEY AT THE MOMENT IM GONNA BUY A NEW ONE EVENTUALLY
Old Apr 20, 2011 | 08:22 PM
JOHN2001's Avatar
JOHN2001
I think your where you should be anything much higher your just chopping air and creating heat
Old Apr 20, 2011 | 08:27 PM
riverrat41's Avatar
riverrat41
^^^What John said.You should get rid of the K&N,they are not good for turbos.They let too much dust pass through.6637 or AIS is preferred here.
Old Apr 20, 2011 | 08:29 PM
Ziggy.'s Avatar
Ziggy.
Keep the TS chip because you can send it to some tuners and they can program it. Just sell the edge, they aren't much count. Don't bother stacking a chip and a programmer, it is pointless and doesn't work, since the TS chip will override anything the edge has put on it anyways.
You should be able to get somewhere around 27-30psi assuming all things are in working order and up to par. I would suggest checking for boost leaks and check the uppipes for any soot from exhaust leaks.
Old Apr 20, 2011 | 08:34 PM
Bigcat350's Avatar
Bigcat350
25 psi is about right for a stock truck and TS tuned chip.
Old Apr 20, 2011 | 08:50 PM
Ziggy.'s Avatar
Ziggy.
Really, I thought you would get just a tad more than that
Old Apr 20, 2011 | 08:53 PM
White350's Avatar
White350
ZIGGY WHAT YOU TALKING ABOUT SENDING THE TS TO GET PROGRAMMED IT ALSO MAKES MY TRANNY SHIFT VERY HARD
Old Apr 20, 2011 | 09:03 PM
riverrat41's Avatar
riverrat41
Cory is telling you that the actual chips can be reburned (changed)to what tunes you want.
Old Apr 20, 2011 | 09:05 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
the TS chip is made by TS but many different tuners use the TS chip also. swamps, wildman, BTS and gearhead are all good choices in tuners and they will put their programs on your chip if you want. for a small fee of course......
and on my stock turbo with a chip i could boost at 30 lbs of boost after i tightened my wastegate rod and upgraded my boots and uppies.....
Old Apr 20, 2011 | 09:07 PM
JT250's Avatar
JT250
AFE II if it's in ur budget.
Old Apr 20, 2011 | 09:09 PM
Ziggy.'s Avatar
Ziggy.
If the ts chip came straight from them it only has canned generic tunes on it, pretty much about the same as what edge, bullydog or superchips offer.
You can send that chip to tony wildman, Cale at Tyrant diesel, matt robinson at gearhead auto performance, and i'm sure there are a few others. They will re-write the chip with their tunes which and ship it back to you.
Old Apr 20, 2011 | 09:12 PM
JT250's Avatar
JT250
I don't know who's tunes are on your TS but Cales tunes at tyrant diesel don't shift hard at all and he can re burn your Ts.
X 2 on that but I haven't done boots or uppies.
Old Apr 20, 2011 | 09:23 PM
JOHN2001's Avatar
JOHN2001
The K&N intake you have is that a real CAI with a cone style filter or a drop in box filter? If its a CAI your good, if its the pannel filter you should get rid of it asap they dont seal very well in the factory box and will let dust threw dusting your turbo and creating premature ware on your engine.
Old Apr 20, 2011 | 11:58 PM
White350's Avatar
White350
i have the fipk kit from K&N its a cone filter and it comes with the new intake tube and K&N's intake box.
Thank you so much everyone i think im gonna go with tyrant diesle to reburn it for 75 bucks it sounds great i love this website i would be lost without it.
Is there any cheap tricks to gane a little power that anyone nos about
timbuktu78
Oct 31, 2009 01:47 PM
Ryan H
Jan 7, 2009 02:19 PM
cleatus12r
32
Sep 5, 2008 09:07 AM
boulderbronco
6.4L Power Stroke Diesel
24
Oct 22, 2007 02:04 PM
Shep VA
Modular V10 (6.8l)
Sep 27, 2007 10:49 PM
