Need Imediate Help!!!!
Old Apr 20, 2011 | 07:44 PM
monomaniac's Avatar
monomaniac
I've got a 74 f100 with a 300 i6 and a 3spd. It acts like it's not getting enough fuel (spittin' and sputtering), and acts like a condenser breaking down... I've replaced the points, condenser, cap, rotor, plugs, wires, coil, fuel pump, water pump, rebuilt the carb, replaced the fuel filters, reset the timing, but it keeps acting up. The engine only has about 30k miles on it... I'm at my cousins in central Alabama and have to be back in tennessee by Saturday, I have to figure out what's wrong so I can get home... It's got to be something simple but I can't think of anything else it could be, please help!!!!
Old Apr 20, 2011 | 07:55 PM
MiddleNameMUD's Avatar
MiddleNameMUD
Recheck your firing order...? Is it getting fuel? You said you rebuilt the carb is the bowl full?
Old Apr 20, 2011 | 08:04 PM
monomaniac's Avatar
monomaniac
Firing order is right, set the float level, and all adjustments on the carb are right on the money. I drove it about 16 mi One way earlier today and it did fine but it started on the return trip.... It'll run perfect sometimes but it'll start acting up.
Old Apr 20, 2011 | 08:13 PM
fordtrucknut77's Avatar
fordtrucknut77
eh try taking your gas cap loose...could be vapor locking
Old Apr 20, 2011 | 08:21 PM
monomaniac's Avatar
monomaniac
The cap that's on it isn't a tight seal, it just kinda "pops" in. It just started this about a week ago.... I drove it to south Florida a month or so ago with no problems whatsoever.
Old Apr 20, 2011 | 08:23 PM
MiddleNameMUD
Ya I'll 2nd that... Dunno kinda stumped myself, it is for sure receiving fuel still?
Old Apr 20, 2011 | 08:24 PM
MiddleNameMUD
Nevermind then...
Old Apr 20, 2011 | 08:25 PM
4x4 Bart's Avatar
4x4 Bart
You have covered about everything.
The ignition switch, yeah make a jumper wire to the coil, to bypass the ignition switch.
Old Apr 20, 2011 | 08:28 PM
fordtrucknut77
it could even be sorry gas, i discovered my lawn mower runs like crap anymore after it gets run a while unless you leave the gas cap loose.....these trucks were not made to run on this ethanol garbage!
Old Apr 20, 2011 | 09:01 PM
monomaniac's Avatar
monomaniac
Well, it gets about 8 mpg, so it goes through gas pretty quick... But that wouldn't explain why it just started....
Old Apr 20, 2011 | 09:10 PM
devino246's Avatar
devino246
Maybe you've got sediment in your gas tank thats clogging the sock on the end of the pickup tube.
Old Apr 20, 2011 | 09:31 PM
monomaniac's Avatar
monomaniac
Well, the inline filters are staying full while it's running and the fuel is clean. But fuel is flowing good, it wasn't yesterday but the new fuel pump cured that...
Old Apr 20, 2011 | 09:59 PM
CalebJns's Avatar
CalebJns
Where in Central Alabama you located? I am still fighting this same issue with my truck...you could try to run it from an alternate fuel source...I know that Wal-Mart has a boat fuel tank for around $50. (Just a thought). Mine will run perfect from an alternate fuel source, it starts acting just like your describing when I hook it back up to the tank...
Old Apr 20, 2011 | 10:09 PM
monomaniac's Avatar
monomaniac
Right now I'm in Alexander City, about an 1 1/2 hours south of Birmingham, I've tried gas from several different places and different octaves but no it doesnt help. My cousin has a 5gal can of 101 octane and I put some of that in it and it did the same thing...... I'm starting to think it's haunted lmao!!
Old Apr 20, 2011 | 10:11 PM
monomaniac's Avatar
monomaniac
Put a gallon can on it running straight to the carb and it still did it.
