surging
Old Apr 19, 2011 | 08:54 PM
silverbull's Avatar
silverbull
surging
My dad just bought an '04 f250 6.0 w/ 82,000 mi. The truck looks to have been very well taken care of and all commonly maintained parts are motorcraft. Also appears to have been kept all stock. He says it will occasionally surge while sitting at a stop. It did not do it when I drove, but I did feel a surge while maintaining a constant speed (about 50 mph). Has anyone else experienced this?
I have a 7.3 and have it pretty well figured out, the 6.0 appears to be a very different animal.
Old Apr 19, 2011 | 09:18 PM
steelhead2's Avatar
steelhead2
I've heard a bad ipr will cause a surge.hang in there,I'm sure someone with a little more knowledge will chime in soon.
Old Apr 19, 2011 | 09:50 PM
CliffordTruck's Avatar
CliffordTruck
i had a problem like that last year but it was at low speeds and idle.. turned out to be my EGR valve
Old Apr 20, 2011 | 02:47 AM
carltonwebb's Avatar
carltonwebb
I would vote to pull the egr valve and check it.....I have had ones do that and found them clogged and the o-rings damaged on them. Easy to get too but sometimes it takes a little persuasion to get it out of the hole if its clogged with carbon.
Old Apr 20, 2011 | 05:16 AM
wulfman's Avatar
wulfman
If maybe early 04 ICP sensor they are known to go bad and cause the surging you are having .
Old Apr 20, 2011 | 05:43 AM
dawiz's Avatar
dawiz
i had the same exact problem with 04 6.0. it would happen while sitting at a light. suddenly it would rev and jump forward. i had it in the shop several times. of course it would never do it at the shop for them and there were no codes. one day it started doing it while sitting at the light in fron of the dealership. i pulled right into the service drive,left it in gear and engaged the parking brake. the service guy came out and saw what it was doing and had one of their techs come out. finally they changed the wiring harness and its been good for over 2 years.
Old Apr 20, 2011 | 05:41 PM
silverbull's Avatar
silverbull
Thanks for the input, we will try the egr valve first.
Old Apr 20, 2011 | 07:27 PM
cheezit's Avatar
cheezit
do you have a knowen good vgt silenoid try that as well
Old Apr 20, 2011 | 08:24 PM
kidoo's Avatar
kidoo
I had surging at around 1500 to 1700 on highway and at iddle, it was my IPR that had debris in. The engine was stalling at times.
I also had and still sometimes have misses at iddle, I touch the wires and was ok for 1000 miles, then once in a while it does it, probably a wire like dawiz said.
joeyd61
Jan 13, 2013 08:28 AM
cajunsuperduty
Oct 28, 2011 03:31 PM
grif95
Jun 23, 2011 11:39 AM
esalter
Apr 24, 2009 10:44 PM
1957F100
Apr 8, 2009 01:16 AM
