WD hitch questions
Old Apr 19, 2011 | 05:21 AM
jweidert's Avatar
jweidert
WD hitch questions
Looking for a quick/basic education. What are the criteria used to determine whether or not a WD hitch is a good idea other than trailer/tongue weights? I presume the considerations are different for a 1/2 ton vs 3/4 or 1 ton truck, meaning someone might consider a WD hitch at a lower total weight in a 1/2 ton truck vs towing the same weight/set up behind a 3/4 or higher ton truck.
At what trailer weight would one consider a WD hitch in a F150? I have never used one an only tow a boat/trailer combo that has a max "wet" weight of 5K-6K lbs. Not sure if there is any advantage in considering a WD hitch (namely for peace of mind) even if it's not entirely necessary.
Appreciate the insight....
Old Apr 19, 2011 | 06:52 AM
MCDavis's Avatar
MCDavis
This thread might help ya:
https://www.ford-trucks.com/forums/1053811-towing.html
As well as this link:
Common Weight Distribution and Sway Control Questions | etrailer.com
Old Apr 19, 2011 | 09:46 AM
LxMan1's Avatar
LxMan1
I always use one. It is a Curt that I got from Summit Racing.
Curt Manufacturing 17002 - CURT Manufacturing Weight Distribution Hitches - Overview - SummitRacing.com
Old Apr 19, 2011 | 10:19 AM
jweidert's Avatar
jweidert
Good stuff guys, thank you both for the references.
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
Dec 19, 2016 03:26 PM
TRHOD121
Oct 10, 2014 08:39 AM
luisp1966
May 10, 2012 10:45 PM
moosehog
All Things Towing
Apr 7, 2010 03:00 PM
cub129
All Things Towing
May 24, 2007 01:01 PM
