O-ring question
Old Apr 18, 2011 | 10:51 PM
cutlass's Avatar
cutlass
O-ring question
Are o-rings in an orb fitting used for a fuel supply system to be oiled before installation?
Thanks
Old Apr 18, 2011 | 10:59 PM
mueckster's Avatar
mueckster
IMHO, I prefer to lube them to keep the o-ring from pinching.
Old Apr 18, 2011 | 11:05 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Same here. I lube every o-ring prior to installation. I use white grease most of the time.
Old Apr 18, 2011 | 11:08 PM
onelionhunter's Avatar
onelionhunter
x3
x3, I always lube orings, motor oil, diesel fuel, grease, anything to keep them from binding on the application at hand. I do not think you can contaminate any system in our rigs to a fault point no matter what you use, just need them to go in without binding, that is the important part.
Old Apr 19, 2011 | 09:11 AM
woodnthings's Avatar
woodnthings
I use a product from Parker called Super O-Lube. A tube of it will last most of use a lifetime!
DavidLM11
Dec 6, 2016 11:14 AM
Nathan Cox
Jul 5, 2016 09:54 AM
MisterCMK
Oct 23, 2015 01:58 PM
emgee
May 11, 2015 08:36 PM
keiseldiesel
Mar 13, 2015 06:10 AM
