Sponsored by: Real Truck
upper balljoint
Old Apr 17, 2011 | 04:47 PM
hondamxr's Avatar
hondamxr
upper balljoint
Is the upper ball joint easy to replace on the f350 it do they have to be pressed in by a shop!!
Old Apr 17, 2011 | 06:14 PM
BigPigDaddy's Avatar
BigPigDaddy
Maybe and maybe. You read, you decide.
Old Apr 17, 2011 | 08:24 PM
rattleNsmoke's Avatar
rattleNsmoke
I replaced the ball joints upper and lower on my solid axle '94 F350 last winter. I took the knuckle to the local garage and they used a 30 ton press to pop them out and press the new ones in. I thought it was deff worth the 20 bucks.
Old Apr 17, 2011 | 09:19 PM
hondamxr's Avatar
hondamxr
well 20 bucks sounds a lil better then a couple hrs of struggle ...thanks for the tip!!
Old Apr 18, 2011 | 06:07 PM
03F350XLT's Avatar
03F350XLT
Couple hrs if ur lucky. U could rent a ball joint press but it can still be a struggle. 20$ well spent I would say.
Old Apr 19, 2011 | 02:27 PM
mwsF250's Avatar
mwsF250
As mentioned, with the right tool (HD ball joint press), it is a piece of cake. Without it, it would be a major challenge.
JLR1953
Mar 13, 2014 05:56 PM
Blue Rebel
Sep 16, 2011 08:11 PM
mh5500
May 9, 2010 06:57 PM
Chuky66
Dec 12, 2004 10:48 PM
billyb
Feb 23, 2001 02:07 PM
