Sponsored by: Real Truck
icp sensor problem
Old Apr 19, 2011 | 08:21 AM
giancarlo's Avatar
giancarlo
icp sensor problem
hi i have a ford f350 2000 diesel 7.3 powerstroke
when i found this truck, in the icp sensor hole in the engine i found a single bolt, so the truck was running without icp.
I buy one on ebay today we install the icp sensor with the adapter.<O</O
If you can help me about this i will appreciate.<O</O
Truck sends "p1280" code that is "inyector control pressure sensor circuit slow" before icp sensor installation.
icp connector is very damaged, but i forgot to buy another one and i am trying to resolve this without having to wait another part from USA.
We are not sure of proper position on wires on icp connector so we try today with 2 different positions.<O</O
In one position the p1280 code remains same.<O</O
in the other position code change to p1210 (icp sensor signal voltage greater than expected) , check engine light turn off.<O</O
But on two option truck runs without power, very poor force.
<O</ODo you have the info of icp connector wires?<O</O
something that you know about this?
also have code p 0380 / p0475 / 0603 i think that none of this is causing this poor power engine.
Thanks!!<O</O
Old Apr 19, 2011 | 09:29 AM
milkman-06's Avatar
milkman-06
giancarlo,
You might post this in the 7.3 forum. I'm sure you will get a more informed set of responses.
Regards,
Russ
Old Apr 19, 2011 | 12:18 PM
giancarlo's Avatar
giancarlo
Thanks, i am doing that, hoping to find some ideas, thanks
Old Apr 19, 2011 | 02:39 PM
milkman-06's Avatar
milkman-06
Your welcome, I forgot to say you might want to go to the top of the messages and search all the forums for your problem
Regards,
Russ
ten.mile
May 16, 2020 04:34 PM
06FUN
Oct 29, 2016 07:53 AM
Navistar Diesel
Jul 28, 2012 07:03 AM
giancarlo
13
May 3, 2011 04:09 PM
Rooster368
Dec 6, 2009 07:47 PM
