A/C line question.
Old Apr 15, 2011 | 04:03 PM
Joe_T's Avatar
Joe_T
A/C line question.
Hi everyone.On my '01 Ranger 4.0,on the high pressure hose from the compressor to the condenser,where the hose bolts to the back of the compressor there is what appears to be some kind of a valve screwed into
the hose assembly.Does anyone know what this valve is for? Is it replacable or part of the line assembly?If while trying to fill the system,if the refrigerant bubbles out of the valve,does that mean there is a blockage or other problem in the system?
Any advice greatly appreciated. Summer is coming soon I hope)
Thank you,
Joe
Old Apr 15, 2011 | 05:32 PM
03 Maz B23's Avatar
03 Maz B23
Sounds like the high side pressure gauge connection port which has a shrader valve just like a tire valve stem. It may need snugged down slightly.
Old Apr 18, 2011 | 12:23 PM
Joe_T's Avatar
Joe_T
No,it's not a schrader valve.The hi-side fill port is on a pipe farther back on the same line.Have no idea what this valve is for.
Old Apr 18, 2011 | 02:18 PM
KhanTyranitar's Avatar
KhanTyranitar
The valve is a high pressure bleed off line. If it is leaking either the system is overfilled or the valve has failed. Either way, you need to replace it. On some you get lucky and can replace just the valve, on others you need to replace the entire hose assembly. Either way, you really should not be doing this work yourself. If your system leaked, it leaked for a reason, and air could have gotten in, and fixing it requires equipment you most likely don't have and diagnosing it requires equipment you probably don't have, and your efforts to repair can make it more expensive to fix later.
Old Apr 18, 2011 | 02:47 PM
Joe_T's Avatar
Joe_T
Thanks for the info,KhanTyranitar.After looking around on AllData,I did find out that it is a pressure releif valve.I work in a garage but not a Ford garage.We're going to hook up the machine to it,evacuate it and find out whats going on.
JoeM1965
Feb 19, 2015 12:43 AM
SuperKram
Aug 12, 2008 11:35 PM
wickware
Jun 8, 2008 11:31 AM
ri_truck_guy
Apr 21, 2008 04:53 PM
Okiedokie
Jun 17, 2004 10:24 AM
