Why no Ether?
Old Apr 14, 2011 | 10:18 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
Mass air flow sensor if has one, gas engines have and do need replacing if etherized! When my gas work vans needed a shot, i drilled a small hole just past the sensor, it started & i saved $250.00!
Old Apr 14, 2011 | 10:21 PM
High Binder's Avatar
High Binder
Originally Posted by Curt's05
i saved $250.00!
Any electronic parts spray cleaner will work too
Old Apr 14, 2011 | 10:39 PM
MisterCMK's Avatar
MisterCMK
Why did those vans need snort anyway?
Old Apr 15, 2011 | 09:46 AM
Nixoninc's Avatar
Nixoninc
Back in the 80s the first generation of electronically controlled Detroits (DDEC-I) were absolutely horrible to start in cold weather. And if they had air starters the the headaches quickly multiplied. A LOT of ether was used that first winter and I witnessed a few engines momentarily "run away" on ether. After that ether was an emergency only item for me.
Jmartenskoop
26
Nov 6, 2012 09:10 PM
Scratcher
21
Dec 26, 2010 10:40 PM
IDIDieselJohn
32
Apr 14, 2010 07:47 PM
Peterbilt376x
Apr 29, 2009 12:39 PM
muscletruck7379
Sep 16, 2003 02:06 AM
