Why NOT to use Ether on a diesel!
Came across this fantastic video a couple days ago on youtube.
I thaught it's important to share this with you guys.
It's ok to use a tiny shot of Ether for emergencys, but there is a correct way of using it, and a very small limited amount!
YouTube - Why you don't use ether and 6.9 tear down p4
That was some smart either to always go to one side of the block, or maybe the glowplugs weren't working on the other side. lol
I have a hard time beliveing that the precup was in the cylinder it would have to beat the block way farther than it was, and there wouldn't have been anything left of it or the piston. lol
the precup may have fallen in the cylinder when he pulled the head.
on
I would love to see the pistons though. There is no room for a glow plug tip let alone a whole precup to fit between the crown and the head. For that matter, what about the valves. Don't see any damage there either.
I'd watch it again, but I don't think I can stand to hear the word "indention" again
I hear you on listening to it again, but there is no way possible the precup got into the cylinder unless it had split into two pieces. lol I have used either on about any diesel you can think of, and the only thing I ever broke was a 5.7 chevy, and I broke one of them holdind a gas rag up to the breather once too. lol I think them motors were hunting a place to die when they left the factory. lol
on
Now I am curious to figure out what really happened there. Either does have a higher flame speed and hurts metal a lot more than a diesel ignition event, but unless he was running the darn thing on that stuff, I can't see either alone doing that kind of damage. Maybe there were pissing injectors on those cylinders? Maybe really weak injectors that popped too early and also resulted in preignition events?
For all we know the heads were redone and the prechambers were sloppy in there from day one. Once they start moving, that I can see causing the damage that we see here.
But again, I've never seen anything like this before so my guess probably isn't the best one out there.
Sounds like them chevies must have been pretty cheap back then for you to go through them like water. Some part of me is still curious to see or even drive one at least once to get the first hand experience. Probably good for a laugh.
Well if you ever drove a vw bug with that stupid auto tranny some came with or road a honda 750 four with the auto tranny you would have a feel for the power they had. lol
The motor was pure junk in my oponion, but to be fair gm never give it a fighting chance.
They were severely under powered and as far as know all had 3.08 gears.
on
I can't help but wonder if GM was only building diesels at the time because it was politically expedient but deep down simply wanted them to go away. Automakers have a history of doing things like that.
