Ether starting
Ether starting
My GP system has went south on me. New Berus too, so it must be electrical. Its too cold for me to go messing with wires and small screws so I've resorted to Ether. Actually she starts quicker on the ether. This engine is being swapped out in a couple of months anyway but I was curios what your views are on ether starting. I was partially raised on a farm where ether was used to start our old Massey Ferguson Diesel tractors.
if i were you i would go ahead and remove and tape the power line to the GP relay at least.... thats where the either start danger is... spray it in and the GP's decide to work just that one time and bam engine damage.... if the GP's are disconnected from power then their is no chance they will come on... i did that on mine i bought all new GP's and the controller took a dump on me so i just unhooked and taped the power wire off until i got a new controller..... better to be on the safe side.
Ether won't hurt anything if used correctlly.
Heres how I always used it.
Have someone crank the engine while you spray a tiny shot at the end of the air breather assembly (NOT directlly in the air cleaner) and it should fire right up, if it doesn't, try another little shot, if it still doesn't fire, leave it alone!
all the way down to 14F i havent needed ether. If you do need to, then it is broken or not working right, just fix it. Having said that, money is a mans priority and if the fix is just too much, do what you gotta do. I vote never need to use it unless you are in a serious emergency and your ride isnt starting, me....i dont find myself in that spot very often and free road side assistance is cheaper than a can of ether.
