ZF5 differences?
Old Apr 14, 2011 | 06:11 PM
drumfield's Avatar
drumfield
ZF5 differences?
Looked all over this forum, as well as the internet, but can't find an answer.
I have 2 zf5 transmissions, with different Ford part numbers.
As I recall, Ford only changed the part number if there was a change to the assembly (but I may be wrong on that).
The numbers are;
F2TA7003RA
F4TA7003DB
Both are 4WD/460.
Does anyone know the differences between them (however slight), and/or if one should be favored over the other?
Old Apr 14, 2011 | 10:58 PM
85e150's Avatar
85e150
Check this out:
ZF Transmission Parts Available From ZFTransmissionParts.Biz
Note two numbers are shown for 7.5/4x4. And just below that it says they are "...100% interchangeable."
That could be what you are looking at. If you can find the ZF part number, it could confirm it.
Old Apr 15, 2011 | 05:10 AM
EPNCSU2006's Avatar
EPNCSU2006
Here's another chart: http://www.zf.com/na/content/media/u...ion_Charts.pdf
I would use the one that is in the best condition, or the newest one if they are each in the same condition. I don't know what the difference would be, but if the number changed, something had to have been updated, and likely for good reason.
Old Apr 15, 2011 | 06:49 PM
drumfield's Avatar
drumfield
Ok, here's the "pertinent" info off of each one.
Transmission 1
Model S5-42
Parts list 1307 050 080
Serial 8302339
Ford Part # F2TA-7003-RA
Total Ratio 5.76-0.76
Build Date 100891
Transmission 2
Model S5-42
Parts List 1307 050 120
Serial 8619175
Ford Part # F4TA-7003-DB
Total Ratio 5.72-0.76
Build Date 072495
One thing I noticed, that from '92 to '94 1/2, the first gear ratio changed, from 5.76 to 5.72. I haven't been able to find anything else different about them.
Old Apr 16, 2011 | 09:34 AM
EPNCSU2006's Avatar
EPNCSU2006
It must be a misprint. Those two part numbers are serviced by the same rebuilt transmission number and have the same ratio range: http://www.zf.com/na/content/media/u...nsmissions.pdf
They should be equivalent, the only difference being any design improvements made between '92 and '94.
Old Apr 16, 2011 | 05:42 PM
thechief66's Avatar
thechief66
The 1st gear is the same for both transmissions, according to FoMoCo (F3TZ-7100-A)
Old Apr 16, 2011 | 07:10 PM
drumfield's Avatar
drumfield
Ok. Must be a misprint on the data tag.
arkredneck
13
Mar 24, 2015 08:37 PM
reamer
Apr 6, 2014 08:58 AM
Ripperg9
15
Nov 2, 2011 02:03 PM
Rob M
Mar 29, 2010 09:02 PM
Boxcarracer944
Dec 11, 2009 09:04 PM
