Zf5 id
Old Mar 22, 2015 | 06:41 PM
arkredneck's Avatar
arkredneck
Zf5 id
I found a zf5 on Craig's list but it's almost 3 hours away. I'm wanting a zf5 47 for my 95 f450. The guy sent me some pics of the trans and the numbers on it are f6ta-7003-na. And 131705003. A quick google search said its a zf5 47 but I wanna make sure. He said it came out of a 94.5 truck but he also has a engine for sale that said was from a 97 so I just wanna make sure before I drive that far
Old Mar 22, 2015 | 06:57 PM
91 Dually's Avatar
91 Dually
ZF.Com says it is an S5-47 diesel unit from a 2 wheel drive truck.
Ford #F6TA 7003 NA / ZF #1317 050 003 1317 050 003 / Engine - 7.3 Application - 4 x 2 / Ratio - 5.08-0.77 / Speedo - Electronic
Model year 96-97
Old Mar 22, 2015 | 07:58 PM
arkredneck's Avatar
arkredneck
Ok thanks I couldn't find it on the zf.com site
Old Mar 22, 2015 | 08:37 PM
Diesel_Brad's Avatar
Diesel_Brad
Doesn't sound like it will work on your F-superduty
Old Mar 22, 2015 | 08:40 PM
arkredneck's Avatar
arkredneck
Why wouldn't it
Old Mar 22, 2015 | 08:41 PM
Diesel_Brad
Originally Posted by arkredneck
Why wouldn't it
because a F-superduty uses a 4wd trans
Old Mar 22, 2015 | 08:46 PM
arkredneck's Avatar
arkredneck
Damn it. Is it because of the brake bolted to the back of it
Old Mar 22, 2015 | 09:06 PM
Diesel_Brad
YUP. that bolts on the same way a t-case would
Old Mar 23, 2015 | 09:30 PM
arkredneck's Avatar
arkredneck
I'm thinking about swapping the zf out of my 97 to the f super duty but I wanted to make sure both trans are what I think they are.
The f super the only number I can find on it are 1307 401 177
The 97 f250 has 1307 401 031
Old Mar 23, 2015 | 09:58 PM
arkredneck's Avatar
arkredneck
Old Mar 24, 2015 | 04:20 AM
Diesel_Brad
A 95 is a s42 with the higher 1st and reverse
A 97 is a s47 with the lower 1st and reverse.
Other than that completely interchangeable as long as they are both the diesel and 4wd housing(4wd and F-superduty)
Old Mar 24, 2015 | 08:43 AM
arkredneck's Avatar
arkredneck
I know the differences was trying to make sure they are what they are suppose to be before I go thru the hassle of swapping
Old Mar 24, 2015 | 05:40 PM
91 Dually's Avatar
91 Dually
Here is the link to that page on the ZF Site....
http://www.zf.com/na/content/media/u...NAL_2-1-09.pdf
Old Mar 24, 2015 | 08:37 PM
arkredneck's Avatar
arkredneck
Thanks 91 dually!!! The tags on the side of my trans are missing and the casting # I got off the passenger side of them doesn't match anything on that list. My luck
UNTAMND
May 24, 2018 06:58 PM
Powerstroke1995
Dec 7, 2011 08:15 PM
Ed Willmott
Sep 22, 2011 09:06 PM
mharring
Nov 24, 2010 10:45 PM
FARM69
15
Oct 18, 2009 11:02 PM
