Bronco II Ford Bronco II
89 bronco trans issue
Old Apr 13, 2011 | 07:35 PM
89broncoll's Avatar
89broncoll
I noticed my bronco wasn't shifting as easy tonight.it's a 5 speed.it doesn't want to go into 1st gear smoothly when I stop and start and the other gears while driving, and will grind if you try to pit in reverse.
Old Apr 13, 2011 | 10:10 PM
89broncoll's Avatar
89broncoll
Cool
I noticed it got worse after driving it more.it seems the clutch isn't working at all but if I push in the clutch while going down the road it does wat its supposed to do. But it seems it doesn't do anything when you stop and go
Old Apr 13, 2011 | 11:39 PM
twigsV10's Avatar
twigsV10
Check the fluid for the clutch master cylinder if low you will need to bleed the air if ok probably the master is likely bad
Old Apr 13, 2011 | 11:57 PM
twigsV10's Avatar
twigsV10
Ok so this is lazy on my part but works, when my rangers clutch won't disengage all the way and the pedal goes all most all the way down befor it does any thing I pop the clutch pedal with my hand several times and it works agan? have done this 4-5 times after Dad drove it 1 time when I was going through deep snow and had to shift 1st\revs alot(Dad+ranger=bad things)
Old Apr 14, 2011 | 12:28 AM
89broncoll's Avatar
89broncoll
Ok.thanks slot.I'll try it out Tomm.where is the master cylinder located?
Old Apr 14, 2011 | 09:32 PM
twigsV10's Avatar
twigsV10
It on the right side of the brake master cylinder and down on the firewall when looking from the front.
Old Apr 14, 2011 | 11:47 PM
89broncoll's Avatar
89broncoll
The cylinder was empty so I filled it up and pumped the pedal a bit and seems to be working ok.is thee anything I should check into?it's not leaking from anywhere I can see
Old Apr 15, 2011 | 10:58 PM
twigsV10's Avatar
twigsV10
If its working that's cool, it could be low from the clutch wearing and the slave extending, or a leak, worst case the slave cylinder.
Old Apr 16, 2011 | 01:52 PM
89broncoll's Avatar
89broncoll
wheres the slave cylinder located? Ive read you have to take the transmisson out to get to it?is that true?
Old Apr 16, 2011 | 01:57 PM
Old93junk's Avatar
Old93junk
Slave cylinder is located inside the bell housing on Ranger/B2 man. trans after 1986.......the trans must be dropped to replace.
83-85 Rangers/B2 had external slave cylinders that are a breeze to replace and bleed.
Old Apr 16, 2011 | 11:58 PM
twigsV10's Avatar
twigsV10
The slaves in th 89s are petty good I have not seen one go bad although posible, check the fluid and see if it goes down, the reservoir is not big enough If you ask me.
Jason Lambert
1978 - 1996 Big Bronco
Feb 26, 2015 01:56 PM
jssblues
28
Jan 25, 2012 09:22 PM
scoug001
Oct 21, 2008 03:54 PM
poffutt
16
Jul 26, 2005 04:45 PM
blue00
Aug 15, 2000 01:24 AM
