More ZF drama
More ZF drama
So, after getting all the info together from some very generous members on this forum (thanks again), I went back to the wrecking yard that has the ZF 5 speed transmission that I was looking at to buy. The first time I looked at the transmission about a week ago, I knew nothing about these things. Now...a little more. The transmission has no place on the back to hook up the drive shaft. It has, instead, a 6"-8" round collar out the back with a shaft sticking out with about 28-30 splines on it, and no place for the speedo cable. I'm assuming this transmission came out of a 4WD.
My question is, can I used this transmission in anyway on my 2WD 6.9 85 F-250? The same guy has another transmission with the same model number (ZF 5 s-42) that came out of an '88 4.9L gasser, with a drive shaft connection on the end of it. Could the back of the Transmission be put on the Diesel version of the ZF?
Thanks
Jonathan
Thanks
Jonathan
You would need to swap the tailshaft housing on the gas trans for the transfer case adapter on the diesel trans but you would also have to swap over the tailshafts which is a ton of work.
One possible thing is if you could find a trans mounted parking brake, then it would bolt directly to the diesel 4x4 trans and would have a 2wd output.
The parking brakes would have been used on F450s.
I say use a 4x4 trans and bolt a transfer case up to it. You'd be surprised how many times that "low" 1st gear ain't so low compared to a granny gear I think the 1st gear in the T19 and ZF5 close ratio transmissions is useless. Reverse in the ZF5 is even taller than the T19, which I find too tall.
I often times wish my 6.9 had a NP435 or T18 behind it when starting off with a load. I have a NP435 behind a 352 FE in my '65 F350, that thing is incredible in 1st and reverse...talk about torque!
It would be sweet if your 2wd truck had a transfer case. Drop it down in low when you got a load.
It's too bad, because that's exactly what I would do...actually, that's what I want to do with this 85 someday...
I was under the impression that this would be a straight swap...Pull the T19, install the ZF. All I'd have to do was convert the flywheel through clutch release bearing to a Single mass setup, and I'd be back to work. Guess i was wrong. From the looks of things, i'm just gonna have to put in a new clutch kit, and keep the T-19.
Using a tailhousing parking brake from a super duty could be a problem on some of these trucks, as on most the tailstock joint is also a slip joint. With the parking brake, the slip joint is in the middle of the 2 piece driveshaft, and the u-joint bolts directly into cups, similar to the rear end connection.
crazed87bronco
02-10-2011 09:15 AM
hagerty_justin
02-05-2011 07:12 AM
buckfoat
07-02-2009 09:25 AM
