how to tell
Old Apr 13, 2011 | 02:07 AM
kosta1974's Avatar
kosta1974
Talking how to tell
i have a 1974 f100 ranger xlt with a 390. how can i tell what tranny i have, also what is a FE engine, do i have one of those, i am a rookie but also scared because i do not want my truck messed up after awhile just want a daily driver..
also reverse lights dont work and bulbs look good, instrument lights dnt work(cant see gauges at night) the headlight switch is shot it has 7 prongs but no one has them!! only 8 prong model, will it still fit?
also can i see photos where iis the oil gauge sensor an temp sensor in engine? and if reverse lights dont work is there something on trans i should check, please photos
thank you!
Old Apr 13, 2011 | 02:12 AM
78 PEB's Avatar
78 PEB
Welcome to FTE!!!! First things firs.......is it an auto trans or a manual? And don't be scared, there are enough knowledgeable folks on here to help you out. We just need to know as much info as you can provide. We will help you get things sorted out!!!!!!!!!
Old Apr 13, 2011 | 02:32 AM
piperig78's Avatar
piperig78
Welcome, yes your 390 is an FE engine, Is your tranny manual or automatic? I believe the reverse light switch depends if its a auto or manual trans. as far as the 8 and 7 prong light switch i'm not sure, but I would replace it before messing with dashlights and other light problems because the bad switch is probably causing it. How this helps
Old Apr 13, 2011 | 03:18 AM
kosta1974's Avatar
kosta1974
sorry
sorry for not furthering my details..its an automatic
thank you for help..much appreciated
Old Apr 13, 2011 | 03:26 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The backup (reverse) lamps work via the NSS (Neutral Safety Switch) with a A/T.
C7TZ-7A247-A .. NSS (Motorcraft SW-600).
Fits: 1968/77 F100/350 w/C6 Cruise-O-Matic / Located towards the bottom of the steering column.
Old Apr 13, 2011 | 03:30 AM
kosta1974's Avatar
kosta1974
is there a photo i can find, i have no idea where this is located, and how do i hook it up...is it the NSS or is there another switch for my reverse lights to work.
Old Apr 13, 2011 | 07:30 AM
mikeo0o0o0's Avatar
mikeo0o0o0
On '74's the neutral start switch is located under the dash on top of the steering column just before it passes through the firewall. This switch works both the neutral start function and the back-up lights.
The oil pressure sending unit is located on the oil filter adapter. This is on the drivers side towards the front of the engine. The temp sending unit screws into the intake manifold just behind the distributor.
Also "FE" is the engine family that includes the 360/390 engines. Unless your VIN's fourth character is "H" or the engine has been replaced chances are you have a 360 rather than a 390. A lot of 360's "magically" become 390's when the truck gets sold. On the VIN "Y" as the fourth character is for a 360.
Externally there is no difference between the two and the only actual difference is a slightly longer stroke on the 390.
Here is a picture of the neutral start switch. It attatches to the steering column with two short screws and is activated by a lever that clips to the shift tube in the column.
Old Apr 13, 2011 | 09:07 AM
BiltFordTuff's Avatar
BiltFordTuff
automatic trans = C6, the light switch may be affecting your dash lights, or could be a bad fuse I would check both, the reverse lights could be anything, the NSS, a bad fuse, or need rewiring, I would think a 8 prong switch would work as long as all the wires are hooked up correctly.
Old Apr 13, 2011 | 10:00 PM
kosta1974's Avatar
kosta1974
truck
yea my truck is a H code, original engine 390 cid.
i will check fuses and all the stuff first before i check the NSS. because the windsheild wipers work and that fuse shares the backup lights
JeepScrambler
Oct 18, 2014 01:37 PM
nappy nate
27
Jan 20, 2010 09:07 PM
FordTrucksKickGM
All Things Towing
Jan 9, 2008 03:25 PM
weekendwander
May 21, 2007 10:56 AM
dj9124
Jun 13, 2005 09:22 PM
