throttle sticking, no acceleration?
Old Apr 10, 2011 | 01:55 PM
navigatorstang's Avatar
navigatorstang
94 5.0 automatic.
about a month ago i noticed the truck would not accelerate at certain times. it happens when i take my foot completely off the gas. ill press the throttle down and get no response. if i take my foot off the gas completely after this, then step on it, it will then react. its like i have to pump the gas pedal... this is intermittant and happens about 20% of the time. i cleaned out the throttle body and IAC. i dont see any vac leaks and i have no codes being pulled by my scanner.
any ideas?
Old Apr 10, 2011 | 02:21 PM
Conanski's Avatar
Conanski
The title of the thread suggests that the throttle is sticking and if so I'd suggest you inspect the cable and linkage for smooth operation. If you got an all clear 11 or 111 with the code reader then it's not likely the TPS is at issue so the problem is probably mechanical.
Old Apr 10, 2011 | 02:38 PM
navigatorstang
doesnt seem to be any binding or anything.. is there a certain lubrication i can put on there?
Old Apr 10, 2011 | 04:30 PM
octaneforce's Avatar
octaneforce
you could wd-40 the linkage where it meets the throttle body. did you remove the body completely when you cleaned it?
awq134
2009 - 2014 F150
59
Sep 16, 2021 06:23 PM
charecter1
20
Apr 1, 2016 10:24 PM
jlintvet
Dec 28, 2015 07:37 PM
tdimatteo
Escape & Escape Hybrid
Apr 7, 2015 12:22 AM
mx21
15
Oct 11, 2014 06:47 PM
