Idit light
Old Mar 19, 2003 | 12:48 AM
mkrog's Avatar
mkrog
Idit light
Why does the idit light stay on when the charging curcut is working. Wife drove 50miles with the light on.When she got home I checked the voltage on the bat. 12+voltsstared the car and checked the alt. output 14.43 at idle 14.83 at 200 rpm.idit light still on
Old Mar 19, 2003 | 01:01 AM
Mil1ion's Avatar
Mil1ion
Idit light
Check all the connections to the Alternator and the Voltage reg for being clean and tight.
Old Mar 19, 2003 | 03:31 PM
Franklin2's Avatar
Franklin2
Idit light
I don't know what you are working on, but if what Dennis said doesn't work, I would pull the connector off the regulator and then turn the key to run(don't start the car). If the light still burns, the wire from the light to the regulator must be touching ground somewhere. If it doesn't burn, then it might be something wrong in the regulator itself. This is assuming you have a system similar to the seperate alt-regulator systems on the older trucks.
Old Mar 19, 2003 | 07:09 PM
Mike W's Avatar
Mike W
Idit light
I would put a piece of black tape over the light and install a voltmeter.
IDI guy
33
Aug 14, 2023 07:02 PM
Odie the Truck
13
Dec 7, 2014 07:10 PM
mknapik
19
Nov 13, 2013 04:42 PM
Lil Red Sled
Jan 11, 2013 08:27 PM
Powerbypressure
Nov 25, 2006 01:05 AM
