Gauges
Old Mar 17, 2003 | 04:05 PM
originalzman's Avatar
originalzman
Angry Gauges
i have a 1987 f-150 4X4 , my charging gauge only works after a good smack on the dash ,, and my fuel gauges (dual tanks) both real WAY past full .. anybody know if i have to take the tanks down or could it be fixed somewhere else ? thanx for any help
originalzman
Old Mar 17, 2003 | 05:43 PM
Mil1ion's Avatar
Mil1ion
Gauges
If both your fuel gauges are pinned to the high side,it means the normal *pulsing wire circuit*is grounding out.
To start ,I would look behind the cluster at possible cluster connection problems.
Old Mar 19, 2003 | 10:03 AM
2wdf150's Avatar
2wdf150
Gauges
i also have the same problem im pretty proficient in electrical troubleshooting for gm vehicles this is my first truck and i was wondering would dielectric grease work also to help in the connector? and where would i locate the dash ground?
Old Mar 19, 2003 | 02:43 PM
Mil1ion's Avatar
Mil1ion
Gauges
Di-Electric grease is a shield against corrosion while also allowing electrical conductivity.
The cluster should ground through the plug-in connector.
Old Mar 19, 2003 | 02:46 PM
2wdf150's Avatar
2wdf150
Gauges
thanx for the input, also did every vehicle come with emission light or was it an option, mine doesn't have one?
Old Mar 19, 2003 | 11:00 PM
steve83's Avatar
steve83
Gauges
2wdf150
What year is your truck? The Haynes manual shows where the grounds are.
Dennis
'87-up uses balanced gauges, so there's no pulsing voltage regulator like older clusters.
originalzman
Pull your cluster & clean all the terminals on the connector & the film circuit. Use an eraser or some REALLY fine (300 or higher) sandpaper. Fine steel wool would work, too, but it might leave fibers that could short something out.
Brittanysmith
Mar 26, 2017 11:52 AM
nissen4
Jul 7, 2016 08:44 PM
okiebronco
May 17, 2016 10:40 AM
AKHunter93
Aug 14, 2015 10:56 PM
Jim Beckers
21
Sep 19, 2014 01:04 AM
