head gasket replacement
Old Oct 21, 2013 | 02:28 PM
mknapik's Avatar
mknapik
Question head gasket replacement
Need to replace my head gaskets in my 94 idit . Looking for any pointers and also wondering about the IP gear cover . Does this have to come off when doing it . Any help is appreciated . Thanks
Old Oct 21, 2013 | 05:43 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
Negative at the ip gear cover needing to come off.
Old Oct 21, 2013 | 06:05 PM
mknapik's Avatar
mknapik
Thanks for the info . Wanted to get it all straight and situated before I got started . Any thing in particular I should look for when taking motor apart . And any suggestions when putting it back together on what I should use
Old Oct 21, 2013 | 06:19 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Heres a write up I did when I did the head gaskets in my '85 van.
All the torque specs are in there, and pics!
https://www.ford-trucks.com/forums/1...l#post12369298
Old Oct 21, 2013 | 07:36 PM
mknapik's Avatar
mknapik
Thanks again will be reading that thoroughly. Any special head gasket to use this might turn into a build before to long if you know what I mean . Another thing I was thinking was a new torque converter . I was looking at the one from rock auto any other experience with them with anyone on here.
Old Oct 21, 2013 | 07:54 PM
mknapik's Avatar
mknapik
Another question I have is can anyone refer me on who to talk to about the stock turbo that came on the idi I wanna get it freshened up while I'm doing all of this work since it'll be coming off
Old Oct 21, 2013 | 08:14 PM
kla94's Avatar
kla94
Type4 would be the one to talk to about your turbo.
Old Oct 21, 2013 | 08:26 PM
mknapik's Avatar
mknapik
Thanks 94 info is greatly appreciated .
Old Oct 21, 2013 | 08:31 PM
kla94's Avatar
kla94
No problem. He has the return line kits, reseal kits for our turbos and a whole lot of other things.
Old Oct 22, 2013 | 10:56 AM
mknapik's Avatar
mknapik
Was wondering about how far I can go with this motor before id have to worry about the pistons and get . Current boost is at about ten and the highest I've had egts is about 650 -700. I have an idit block .
Old Oct 22, 2013 | 05:14 PM
Dieselamour's Avatar
Dieselamour
Maybe Superior Diesel in Richmond. I have worked with them over the phone and they seem to be nice people.
Old Oct 23, 2013 | 07:08 PM
mknapik's Avatar
mknapik
history of truck / reason for hg replacent
I have a 94 idi factory turbo . I bought the truck four months ago . Previous owner had replaced injector pump injectors and injector o-rings along with radiator and heater core and glow plugs and controller. After about a month of having I found oil in the radiator and replaced the oil cooler gaskets and flushed out the motor best I could and every week for two weeks after that to get it all out. Then another problem arose I would have excellent power through first and second and then it bogs down horribly in third . Then on top of that I have to do the water trick on the IP to get truck to start but its new or at least five months old .
Now comes the over heating I checked every possible peice of the cooling system thouroughly and can't find nothing wrong. It won't over heat unless I'm on the highway going on a long ride 20 miles plus that's when it just climbs like instantly . I have both gauges mechanical and original the mechanical one works when it wants. I thinks it was half a**ed but the original one works and the tranny temp gauge I have hits 250 in that period also but my tranny cooler will be cool and the fluid isn't burnt and is a nice red . I have a nice sweet coolant diesel mix smell also so was thinkiking exhaust part of the head gasket is leaking .
Sorry for the long post but just trying to get info to yall on truck and reason for tearing it apart
Old Oct 23, 2013 | 08:55 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
hows the oil and coolant looking? what about the levels? any signs of mixing and or dropping? is the exhaust leaving a constant strong white cloud along with a major sweet smell and or even see vapor? sure the water pump is ok? no weeping and or a large amount of end play?
so with questionable gauges,what leads you to believe the engine is actually overheating? what tell tale obvious symptoms are you seeing when the faulty/questionable gauges are reading high?
Old Oct 23, 2013 | 09:28 PM
mknapik's Avatar
mknapik
Its a nice big cloud that engulfs the truck and lasts for about twenty mins then calms down but still puffs while driving just not as bad . Oil is good . Coolant was down to fins filled back up added stop leak. That seemed to stop the smoke but not over heating . The reason I know its over heating is the light by the wts light popoed on I shut down immediately and pulled over. Got on truck popped hood and couldn't even grab top radiator hose and saw a lil bit ofoil/water in a lil spot on water pump boiling. No weeping or end play on water pump.
Old Oct 24, 2013 | 04:40 PM
mknapik's Avatar
mknapik
Was recommended by a member to check the cooling fan So I used a broom handle to try and stop it once it got good and and hot and it took almost no effort . I'm assuming that's bad.
