Sponsored by: Real Truck
Transmission Fluid Temperature Sensor
Old Apr 9, 2011 | 03:48 PM
Phillip Vega's Avatar
Phillip Vega
Im having a problem with my Check Gauge light coming on and Tow Haul light flashing on my 04 F-250. I got a Transmission Fluid Temperature Sensor from my local Ford Dealership. They also said i needed to replace the Transmission harness for this application. My questions are, Is Mercon SP the only ATF that can be used on the Torque shift transmission, and do i need to replace the harness or just the sensor? I have read up a little on this and so far everything say swap out the sensor and your good to go. Any help would be appreciated. Thanks
Old Apr 10, 2011 | 05:36 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
MERCON LV is replacing MERCON SP. Use one of those or be prepared for expensive transmission repairs.
Usually it's the sensor that fails, but sometimes it's the harness. While it is apart it doesn't cost much more to change both, then you won't have to do it again.
usmarine1979
Aug 15, 2016 01:31 AM
Gwilkrrs
6.4L Power Stroke Diesel
Jul 1, 2016 07:54 PM
mgoodwi9
All Things Towing
Nov 2, 2015 09:53 AM
Pyancey
Jan 16, 2013 09:08 PM
Thomasbeau
Jun 2, 2010 09:44 PM
