Sponsored by: Auxito
engine interchange
Old Apr 8, 2011 | 01:28 PM
MR544's Avatar
MR544
engine interchange
Just picked up a 97 f150 4x4, standard shift, with a 4.6. The engine has a miss, and the coolant system gets pressurized as soon as I start the engine. Rather than change the head gasket I was considering swapping out the engine as this one has 146k on it. My vin digit is 6 indicating its a 4.6 winsor motor. I have an opportunity to buy a low mileage 4.6 from 2002 explorer. Does anyone know if the base motors are the same, can I switch my intake and accessories and use the explorers motor. I do not have a vin for the explorer but the label on the valve cover reads as follows, 04/06/01 (year I assume), 1G302BA, REP, 77135973. Any info would be appreciated thanks
Old Apr 8, 2011 | 05:29 PM
steve(ill)'s Avatar
steve(ill)
for $10. pour this in and see what you think. You got nothing to loose. I have had excellent success with it... leak was probalby not as bad as you mention.
Bar's Leaks Liquid Copper Block Sealer
Old Apr 8, 2011 | 07:13 PM
MR544's Avatar
MR544
someone already pulled the thermostat, and there is residue in t he resivior and the hoses
Old Apr 9, 2011 | 08:52 AM
phil6608's Avatar
phil6608
Yes,
4.6 is a 4.6 so you can swap anything you need off of your old motor.
Other then yours has non PI heads and I'm not sure what year the went to PI heads. So you would need to find out if it has PI heads.
The intake-manifold will be different from PI to non PI.
Old Apr 9, 2011 | 09:26 AM
MR544's Avatar
MR544
intake
do you know if I could use the upper portion of the intake from the non pi and bolt it up to the pi intake
Old Apr 9, 2011 | 09:27 AM
MR544's Avatar
MR544
do you know if the upper portion of the intake (throttle body) from the non pi will bolt on to the pi
Old Apr 9, 2011 | 10:05 AM
phil6608's Avatar
phil6608
The throttle body and the aluminum elbow it bolts to will blot to ether intake the same.
Old Apr 9, 2011 | 10:10 AM
MR544's Avatar
MR544
thanks that some good info, the only thing holding me back now is determining the number of bolts that secure the flywheel. My truck is a stick so I'll need to use my flywheel, as I understand it some engines use 6 bolts and others use 8. Read somewhere that windsor motors use 8 and romeos use 6. I'll need to find out if flywheels are available in both configurations
Mauiford
2004 - 2008 F150
Apr 2, 2017 06:51 PM
BadBee
Dec 15, 2015 04:10 PM
ClovisT
Dec 1, 2014 07:53 PM
chard17
1997 - 2003 F150
Mar 25, 2014 06:10 PM
Aerocook
Jun 21, 2010 07:49 PM
