Cant find TDC marks?
Old Mar 18, 2003 | 10:09 PM
Racerdave's Avatar
Racerdave
I have no clue where the TDC marks are on my 302? I looked everywhere? The engine was rebuilt not long ago by the PO. I was thinking maybe he painted over them? Where are they suposed to be? I thought they were suposed to be on the thing that the fan mounts to? I am totaly lost on this one? my Dizzy has a mark in it that shows TDC when the rotor is on it, but im not to sure how acurate that is?
Old Mar 18, 2003 | 11:07 PM
tracman's Avatar
tracman
You should have one of two setups (atleast that I've seen) One, timing marks will be on the Damper(harmonic balancer) and then you will have sort of a bracket mounted to the engine with an Arrow pointing at it.
Two, you will have a bracket with the Timing marks on it and a small Line cut into the Damper which you line up with the markings on the bracket.... (I say bracket, but it is actually just a small metal piece bolted to the engine)
Old Mar 18, 2003 | 11:10 PM
Mike W's Avatar
Mike W
The timing marks are on the harmonic dampener. You should see TDC and a few dergees marked out.
Old Mar 19, 2003 | 05:43 PM
Racerdave's Avatar
Racerdave
got it, they were covered in grease and dirt, I couldnt even tell there was a tab of metal, it was bad, now its all clean and ready to time! thanks!
84respass
Oct 5, 2010 10:09 PM
flipklos
Feb 23, 2009 10:17 PM
royt911
1983 - 2012 Ranger & B-Series
Dec 3, 2008 11:28 PM
95F350XL
15
Nov 16, 2007 07:31 PM
CJ7
Nov 25, 2003 05:42 PM
