Lowering rear suspension
Old Apr 6, 2011 | 05:13 PM
David1958's Avatar
David1958
Does anybody out there have hands on experience lowering their rear suspension on their van. I have a 1989 E-250 and would like to lower the rear 2". I read somewhere that the shackles made for the pick-ups work for the vans as well so I purchased a set of Belltech 6425 lowering shackles. Well, they don't fit and now I was wondering if anyone else has had any success lowering their rear suspension using the shackle method. I don't want to remove a leaf or otherwise modify the springs, I really would like to be able to accomplish this with the shackles. It seems easy enough I just haven't been able to find a shackle that fits. I would appreciate any suggestions? Thanks.
Old Apr 8, 2011 | 05:26 PM
SilverE350's Avatar
SilverE350
Most people are a little obsessed with raising the front of the van by 2" so they can fit larger tires under it, and here you are wanting to lower yours. I would say to go to your local spring shop and ask them. The stock shackles already point up so you might run into a clearance issue.
Old Aug 22, 2011 | 01:05 AM
james843's Avatar
james843
go to the junk yard and get a stock set and thke them to a welding shop and have them extend them 2"
Old Aug 22, 2011 | 05:31 AM
JWA's Avatar
JWA
Just being nosey but why lower the suspension?
Old Aug 22, 2011 | 05:54 AM
james843's Avatar
james843
4 the look
Old Aug 22, 2011 | 09:53 AM
JWA's Avatar
JWA
Originally Posted by james843
4 the look
Oh okay!
I like the new ride height only because it lowers the cargo deck and would be easier to enter and exit. Of course ground clearance would be an issue---have to avoid loose coins laying on the road!!
Old Aug 24, 2011 | 07:52 PM
David1958's Avatar
David1958
I like the level look. With the 250's and the 350's the heavy springs usually lift the back end a couple inches and I don't care for the look. Also by lowering the rear I am able to park the vehicle in my garage without letting air out of the rear tires.
Old Aug 25, 2011 | 10:38 AM
redtanrt10's Avatar
redtanrt10
James, looks real sharp! How is the ride and handling compared to stock? Mike
BEN WHEELAN
Feb 27, 2017 03:03 PM
Trev5402
2004 - 2008 F150
Jul 18, 2016 10:27 AM
Nothing Special
20
Jun 13, 2015 08:01 PM
brutus67
Apr 29, 2014 02:24 PM
OldWoodsDiesel
Oct 22, 2012 07:45 AM
