Need opinions
Option A:
Keep the current height (4" lift), replacing both front and rear springs with lift springs, therefore eliminating the blocks (front and rear)
Use a massive drop with my dads trailer (6'') and a really massive drop to pull our single axle at work (10" drop)
Deal with the gooseneck being too short and leaning backwards (havent even made a hitch yet)
Deal with the height of the bed concerning loading things in it
Add a method of controlling the axle wrap
Keep the good looks and good MPG (16-18, N/A for now)
Option B:
Go back to stock height (for a 4x4), replacing the drop brackets for the TTB (one is cracked anyway)
Buy new tires (4, already have stock wheels)
Lose the insane axle wrap/hop
Use a straight shank for most trailers (and i would use a W/D hitch again) and small drop for the mower trailer
Don't need to do anything fancy for a gooseneck trailer
Lose MPG (dunno how much)
Buy a new stock speedo gear
Option C:
??? Make a suggestion ???
Way i see it, I have to spend money either way. And have to try and locate stock parts. I would probably try to use some 235/85's with option B.
A has some perks with looks and MPG, but i lose towing power with my (corrected to) 3.08 ratio and need a massive drop to pull a trailer (6" with my dad's, probably 8" with most other tandems). Not real sure as to the cost.
B has some perks with easier loading, better suited for trailers, get my 3.55 ratio back. I wont have to buy new springs, just find some factory rear blocks (2"??). Beg/trade/steal some front TTB brackets... Buy new tires (that's gonna hurt...
)So what say you? I don't think i've got any parts worth trading or selling so i'd have to buy everything...
I don't do any towing cause between bad brakes and no hitch i'm not ready for it. I do like to tow though.
If money wasn't such a big deal id take her up to 6" (the right way) and get a crew duallie (I'm dying for one...) for towing...
Benefits of loosing the lift: Stability, towing, gooseneck hitch, power, no axle wrap and cheaper tires.
Downfalls of loosing the lift: MPG, Looks, and everything else you listed.
I am in favor of dropping it down, this is just me but i personally dont care for the look of lifted trucks in general, i prefer the savings on towing and it makes it a more marketable truck for working on in the future, if your going to do something, body lift it for a nifty turbo setup from a PSD XD! So im x3 on loosing the lift.
If it was my truck and I was gonna set it up for working I'd get a dana60 and springs from an f350, would be like a 3" lift over a stock f250.
And to get better gearing I'd get some 33's or stock tire size.
As much as i'd like to I simply can't afford a 6" lift and gears...
Is this a parts truck? If i could get it i'd buy the whole thing off you...
Might run into a problem if i ever get a 5er hitch though... or have some crazy *** mount...
My vote is for Option B, then leading into Option C.
Start with Option B by bringing the chassis back down to stock level. Then transition into Option C in the form of a body lift.
If you do it right, you can slowly source out a set of Craigslist tires for your stock rims. I don't like the mention of a cracked/damaged TTB drop bracket...I'd ditch that for a stock TTB bracket. For tires, my last set was $100 for a set of 4 matching. My current set of non-matching were free because I traded work for them
If you start looking now, you can find deals between now and when you get to doing the work on your truck. Keep your current tires around, because when you fit the body lift onto the truck...then you can run your bigger tires again. (this will raise the chassis a little bit over stock, but less than a 4" lift)Another reason for lowering the truck, my truck is VERY frusturating as the hitch is also set too high for any practical use. Even with a 4" drop hitch, the tandem axle dump trailer is leaning all the way back on the rear axle.
I don't see why getting stock sized tires and losing the lift will hurt MPGs? The bigger tires are offering an overdrive basically, but they also take a decent amount of power to turn them at the same time...and the amount of rubber on the road is way more than a 235/85R16.
I really do like the way it sits now, and if i could lower the frame and still run my "fat tires" i might do that...
It will be interesting to lift the bed 4" though.... I really should lift it another 2" to get some room for the tires, but if i go back to 235/85s i guess i wouldnt need to...
33's would be what... a 285/75? If i dropped it i'd likely go with the stock 235/85.
I may need to put in an AAL front and 2" block rear to clear tires... dunno yet... I do know that front block needs to get gone...
