View Poll Results : Whitch would be the best choice?
Option A - Keep the lift
23.81%
Option B - Lose the lift
42.86%
Option C - Suggest something
33.33%
Need opinions
Apr 3, 2011 | 07:18 PM
I'll have to look into this...
Apr 3, 2011 | 11:21 PM
i did the add a leaf on my 250 and i got 2 inches of lift just from that
Apr 4, 2011 | 06:06 AM
4 inch lift is not a big deal. what i would do is put the turbo on, dump the ifs, put a dana 60 in the front, regear to 4.10, and use the drop hitch.
that is how i had all my trucks setup, and never had any problems with towing or power.
Apr 4, 2011 | 06:55 AM
Cant afford a SAS right now...
I sent a email to a local place that builds springs and see what they can do and what their prices are like. If it's not too bad i may get custom springs front and rear....
If i ever start really towing a lot, i'll probably get a crew duallie with 4.10s and build it up. I kinda want to keep my 3.55 (effective 3.08) ratio since i mostly just drive it...
Apr 4, 2011 | 09:28 PM
Hey AUNE! Clear your PMs so i can send you one...
So Option A looks like it's going to run about $700+
I'm now leaning toward option B, with a twist...
-Question- Can you put a gear vendors OD on a 4x4 truck?
If so then i might go back to stock height and save my pennies for an OD box.... or maybe a brownie....
On a semi related note, i finally fixed my front axle so my 4wd works...
Apr 4, 2011 | 10:04 PM
You can put an OD unit on a 4x4, you just can't use it while in 4x4 cause it mounts after the t-case.
Now if you got a ranger torque splitter that's a whole different beast.
Apr 5, 2011 | 06:54 AM
If i needed 4x4 its a good chance id wouldnt be safe to use OD, but you've got a good point.
Apr 5, 2011 | 04:11 PM
That's true, no need for OD while in 4x4.
Only thing I like about the ranger torque splitter is the extra shifter, how cool is having 3 shifters!?!?!
But you'd have to move your trans and t-case, back 8" and get bucket seats, lotta extra work.
Apr 5, 2011 | 04:32 PM
With a brownie i'd have 3 shifters too....and 12 speeds...
Apr 5, 2011 | 08:45 PM
throw in a 2spd rearend and youll have 24 LOL
Apr 6, 2011 | 06:58 AM
I don't think i've got a long enough truck for the 60 speed we were talking about...
Apr 6, 2011 | 01:12 PM
Quote:
Originally Posted by
Otahyoni
just double your 4 speed with a 6 speed then youl have a suicide shift with 24 speeds, it would be like driveing an old mack...instead of an old school bus...
Apr 28, 2011 | 06:40 PM
motor-man
Apr 9, 2010 07:30 PM
Craigwell
15
Jan 18, 2010 08:23 PM
linckeil
Aug 27, 2008 04:42 PM
jomac11
All Things Towing
32
Oct 9, 2007 11:41 PM
lyager
All Things Towing
Mar 2, 2005 04:08 PM
4 ,
73 ,
85 ,
blocks ,
build ,
f250 ,
idi ,
leaf ,
lift ,
lifted ,
matching ,
spring ,
tires ,
truck ,
ttb
