Stuck Diesel
Old Apr 1, 2011 | 11:42 PM
hooder37's Avatar
hooder37
8th Gear
Stuck Diesel
'88 F-350 Diesel nat. aspirated, Manual Trans. Engine will turn 90 deg then stuck. I removed the injectors a couple of weeks ago and put Marvel Mystery oil in the cylinders, but the engine still will not turn past 90 degerees. Any suggestions?
Old Apr 1, 2011 | 11:51 PM
Plain Jane's Avatar
Plain Jane
withdrew my post
Old Apr 2, 2011 | 01:06 AM
89_f150_mudtruck's Avatar
89_f150_mudtruck
maybe it broke a valve and the valve is now hitting the head when the piston comes up
Old Apr 2, 2011 | 10:42 AM
CWPottenger's Avatar
CWPottenger
Yep sound like a broke valve or connecting rod.
Old Apr 2, 2011 | 11:02 AM
bashby's Avatar
bashby
Take the valve covers off and look for loose rockers (bent valve) or signs of a broken valve. It could be a glow plug broken off and hitting the piston also. Probably may as well just pull the heads and see whats up.
boogaloo
1978 - 1996 Big Bronco
Mar 3, 2011 03:08 PM
justforkicks
Bronco II
Aug 26, 2010 02:49 PM
keeno
Aug 30, 2008 05:00 PM
51dueller
Flathead V8 & Flathead 6
13
Dec 22, 2003 10:56 AM
