1978 - 1996 Big Bronco
Wiper relay
Old Feb 27, 2011 | 03:12 PM
boogaloo's Avatar
boogaloo
Wiper relay
The wipers on my 90' fullsize get stuck on. It happens in the delay mode or regular mode. I can hear a relay clicking somewhere but I can't find it. Is there a separate relay somewhere that gets stuck in the on position or is it integrated into the switch? The only way I can turn the wipers off is to either turn the ignition off or hit a big pothole. It's making me crazy not being able to turn the wipers off!
Old Feb 27, 2011 | 11:55 PM
greystreak92's Avatar
greystreak92
Sounds like the problem is in the multifunction stalk on the column. If the wipers run and do their intermittent thing like they are supposed to, but they just won't shut off, then the problem is not with the time-delay relay but with the switch itself. The multifunction stalk is a joy to deal with (can you hear the sarcasm). Requires removing the column surround and probably the ignition tumbler. I'm not 100% certain with the pre-'92 models.
Old Mar 2, 2011 | 11:40 PM
boogaloo's Avatar
boogaloo
My wiper switch is right next to the headlight switch on the dash. It's not on the column (thankfully). I think I will just replace the switch and see what happens.
Old Mar 3, 2011 | 03:08 PM
greystreak92
Yes, then you are in much better shape than those of us with the multi-function stalk. Replacement requires a lot of tedious removal of a lot of things that aren't directly related to the stalk.
mytimeistoday
Jan 26, 2015 06:38 AM
donmi
Aug 27, 2012 11:44 AM
ryito1122334455
Jan 22, 2012 05:06 PM
Schuby
1997 - 2003 F150
Feb 23, 2011 08:53 PM
john-utah
1983 - 2012 Ranger & B-Series
Feb 2, 2004 12:32 AM
