diff leaking UT explorer
Old Apr 1, 2011 | 01:49 AM
kbrennan's Avatar
kbrennan
Can anyone tell me whats involved in removing the axles from rear diff of my UT explorer. It has the independent setup and seals are leaking.
Old Apr 1, 2011 | 05:44 PM
steve(ill)'s Avatar
steve(ill)
axle is trapped between the gear box and wheel hub. You will need to remove the tire, barkes and caliper. Remove the ball joint to A- frame joint. Remove the center nut on the axle. PUll the A- frame and wheel hub/bearing off the axle shaft and set to the side. Now you can work on the axle shaft to pumpkin joint.
Old Apr 1, 2011 | 06:30 PM
kbrennan's Avatar
kbrennan
diff seals explorer
Steve,
Thanks for your reply, I can get the hub/bearing assembly off the axle but just wondering if there is any retainer/circlip holding the axle into the pumkin. I take it thats what you guys call the diff.
Kyrian.
newguys76
Nov 23, 2012 09:00 PM
Awitte58
Jun 3, 2011 09:02 AM
mi1
New Member Introductions
Jul 1, 2008 07:43 PM
powrstrkr
May 2, 2008 12:05 AM
mantta
Garage & Workshop
May 23, 2006 06:36 AM
