Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Any Chainsaw Experts?
Old May 22, 2006 | 06:05 PM
mantta's Avatar
mantta
I have a Homelite chainsaw Model UT10947D and it keeps dripping bar oil when not in use. It leaks in the area where the cover is over the chain sprocket. Any ideas what to look for or a cure? Thanks.
Old May 22, 2006 | 11:01 PM
jb1390's Avatar
jb1390
If you take the bar off, you can see a little hole in it, which is where it oils the bar and chain. There is a hole on the plate of the saw where the oil is fed. Get a can of brake cleaner and clean that hole out real nice. If you are comfortable enough, take the saw mostly apart and clean it out, it will make a world of difference for making it last.
Old May 23, 2006 | 06:08 AM
lenny1carl's Avatar
lenny1carl
another thing to think of is if you don't clean out that area often the chips soak up oil and they will drip during down time. but as stated obove clean it, clean it, clean it
Old May 23, 2006 | 06:36 AM
GlennFordx4's Avatar
GlennFordx4
I don't have my brake downs here to tell me what saw that is but many homelites have had this problem,one that comes to mind is the super 2 or xl mini and the Bandit.I have spoke with homelite tech and this is what they told me keep the oil 3/4" to 1" below the cap when filling it and when you are done with it loosen the cap to relieve the pressure in the tank.I know some of the newer small saws that you get at homedopey or blowes leak oil at a rubber connector under the muffler and is just a bad design.
Bdox
Jan 12, 2014 11:07 AM
preppypyro
16
Jun 15, 2008 10:47 PM
chainsawmadness
15
Oct 21, 2005 12:04 AM
Ghostgunn
Garage & Workshop
Apr 11, 2005 05:13 PM
DrFord
Jan 17, 2002 12:21 PM
