supercab corners
Old Mar 31, 2011 | 08:46 PM
76250_4x4's Avatar
76250_4x4
supercab corners
im gunna be doing my cab corners in the next few weeks on my 94 and im trying to find a good diy walkthrough. ive searched and searched and have limited results. im curious as to what most people do with the foam that is in the cab corner. to me i want it gone as im sure it holds water and makes it rust out faster. if anyones got some hints or tips on supercab cab corners id like to hear/ see them thanks!
Old Apr 24, 2011 | 07:33 PM
pdqtimetrialer's Avatar
pdqtimetrialer
I have a regular cab and facing the same dilemma on the cab corners - how to protect them from future rot.
I pulled as much of the foam out as I could, as it seemed to act like a sponge and hold water. Then I used a propane torch to warm the area and dry it out. On the driver's side I had to weld a small patch to cover a hole. I then used ospho on the interior, followed by cold galvanizing paint, followed by a waxy rust inhibitor. It still leaves a cavity wear water can collect, especially in the northern climbs when snow gets tracked in.
Any ideas on how to fill the internal cab corners to prevent water collection? I'm thinking of packing it with grease once I get the whole truck repainted.
Old Apr 24, 2011 | 09:30 PM
ostrx250's Avatar
ostrx250
i believe the foam is only for sound reduction.hopefully someone has some info
Old Apr 24, 2011 | 11:28 PM
SideWinder4.9l's Avatar
SideWinder4.9l
I would cut/replace the corners....And use POR 15 on the inside....Maybe drill a couple drain holes....You can put plugs in them if you want to then...
kadrocker
Apr 29, 2014 06:06 PM
4x41977
Nov 15, 2012 08:44 PM
danyzf95
Dec 20, 2007 12:03 AM
F100man
Paint & Bodywork
Aug 28, 2007 09:39 PM
TractorGuy
Paint & Bodywork
May 20, 2002 12:47 AM
