1979? SuperCab F150
Old May 16, 2002 | 08:05 AM
TractorGuy's Avatar
TractorGuy
1979? SuperCab F150
I have found a 1979 (I believe) SuperCab F150. The body is in good shape except for the rear cab corners. How hard is it to find body parts for the supercabs? For the corners, will standard cab corners work? Thanks!
Old May 20, 2002 | 12:23 AM
F350SuperCab4x4's Avatar
F350SuperCab4x4
1979? SuperCab F150
there are alot of company's who make the supercab corners. LMC has them for around $50 per side. the panel goes from the door jamb around to the back of the cab and 13" up from the bottom. reg cab will work if the damaged area is within the corner. but chance's are it will extend past that point. i put a pair on a truck i had 5 years ago. came out perfect. not bad for a first timer.
good luck
Paul
Old May 20, 2002 | 12:47 AM
F350SuperCab4x4
1979? SuperCab F150
danerisfree
May 7, 2014 08:34 AM
kadrocker
Apr 29, 2014 06:06 PM
eviljmizfit
Mar 18, 2014 01:12 PM
78f250lj
WTB - Ford Trucks & other vehicles
Feb 9, 2014 02:27 PM
Frenchy
Paint & Bodywork
Apr 19, 2012 10:09 AM
