Transmission HELP needed
Old Mar 31, 2011 | 06:19 PM
ybnrml22's Avatar
ybnrml22
I have a blown 351 modified with the 429/460 bellhousing. Bought what I was told was a 351 Modified, come to find out is a 351C. It is going in a F-250, with a 4 speed manual transmission with granny gear. Can anyone tell me is they make a bellhousing and flywheel to use to get the 2 to work together?
Old Apr 1, 2011 | 09:59 AM
clovins's Avatar
clovins
If i'm not mistaken, the Cleavlands and the Modifieds bolt up the same. The Windsors are different.
Old Apr 1, 2011 | 03:45 PM
ford_pickup's Avatar
ford_pickup
I actually believe the 351C has the same bellhousing as a 302/351W, so if you have a standard all you need is a windsor bell housing, if you have an automatic you need a different tranny or some crazy adaptor plate
Old Apr 1, 2011 | 05:45 PM
brownfoot's Avatar
brownfoot
yep, Cleveland is the same as 302/351W on the back end
Old Apr 1, 2011 | 06:09 PM
impalaslayer's Avatar
impalaslayer
as i told you yesterday, you need a bell from a 300/302 with the 435 behind it
ybnrml22
Mar 31, 2011 07:49 PM
fastredford
13
May 4, 2010 08:33 PM
notsoswwuyd
Sep 20, 2004 06:51 AM
rk40977
32
Oct 19, 2003 10:13 PM
fullspeed1979
21
Feb 2, 2003 09:06 PM
